Last stabile version 2.06.1 - (09.09.14)
Silverwing
Hey Ahmet,
I noticed a bug with the Node Graph.
If you pick a node at a corner to scale it and then drag to make it smaller... If you drag far enough it will allow you to go into negative scale... after you have done that the node looks really messed up and you can´t select it anymore.
Cheers,
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
dinf
Nested Renderinstances seem to not work in: 2.04, 2.06 and 2.10. Nested are Renderinstances in a Cloner wich also has ri active.
Is that still, or did it work until now?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
dinf wrote:Nested Renderinstances seem to not work in: 2.04, 2.06 and 2.10. Nested are Renderinstances in a Cloner wich also has ri active.
Yes, cannot support it yet. It's very complex for realtime updates.
ratata
Hello,
Noticed another node graph glitch, you cannot link turbulence node to invert node, but if you go from turbulence to clamp or mix.. then you can link that to invert.
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
dinf
OK thanks. It seems to be on your list, that is important to me.
Effekt-Etage
can the nodegraph be altered by xpresso, for example the range mapper node?
this would be a great feature.
Effekt-Etage wrote:can the nodegraph be altered by xpresso, for example the range mapper node?
you can connect any xpresso node to octane textures. But this will not be presentated on nodegraph editor
grain
I am also getting a virus warning, W32/Sality.AO, using Panda antivirus. Has anyone else had this issue? Should I ignore it? File is in /Libs64_200/octane.dll
salmon
@grain Please make yourself a favor and uninstall Panda.Try with another one (i.e. eset is a good choice)Panda is widely recognized as the worst antivirus.
