OctaneRender™ 2019.1.1
abstrax
Zay wrote:AI up-sampling still fails on win7 for me. It will render to the end and then all GPUs fail.
Started logging on 27.09.19 09:19:25
OctaneRender Enterprise 2019.1.1 (6000101)
Up-sampling error: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered
CUDA error 700 on device 1: an illegal memory access was encountered
-> failed to copy pitched memory from device
Well, that's embarassing. I can confirm that it seems to happen in all cases. We will fix it as soon as possible. Sorry about that.
J.C
Hello Otoy,
thank you for the fixes!
abstrax wrote: [*] Fixed legacy volume render not matching between 2018.1. (To enable the legacy mode tick Emulate old volume behavior in the kernel settings)
The incompatibility is still there:
System – Windows 11
funk
BUG: Toon materials using "camera" light, render black unless you add toon light to the scene
This works in 2018.1, but got broken in 2019.1
1. Load the scene in 2018.1 and 2019.1 and render to compare
2. Connect the toon point light to the object layer map. This lights up the toon material, but it's lit differently to 2018.1, so this is another new bug.
coilbook
there is still a bug when using adaptive sampling and if there is 20% of noise left to finish, GPU usage drops from 99% to like 40%-20% Doesn't it make more sense to keep GPU at 100% all the time to finish faster?
Also reflected light through specular material (chrome) and DOF applied to it makes it is very noisy. Anyway to improve it? Denoiser is useless there because of its jumpy blotchy movement, especially for animations .
Would be nice to have temporal denoising like in Disney's approach https://youtu.be/cwFTwrJhJOc
I am not kidding you what took 5000 samples to finish as far as noise in octane 4 now takes 20000
3dworks
cannot install slave render on macos. what i get in terminal is this:
Last login: Sat Sep 28 12:49:13 on ttys000
Lion:~ 3dworks$ /Volumes/OctaneRender\ Enterprise\ Slave\ 2019.1.1/install\ daemon ; exit;
### OctaneRender Slave Daemon Installation ###
HINT: To keep the default setting, just press ENTER.
On which network port should the daemon listen?
Please enter a number between 1024..65355 (default: 48000):
available GPUs:
/Volumes/OctaneRender Enterprise Slave 2019.1.1/install daemon: line 70: /Volumes/OctaneRender Enterprise Slave 2019.1.1/.OctaneRender Daemon *.app/Contents/MacOS/octane_slave: No such file or directory
Which GPUs should be used by the slave? Please keep default or enter a
comma/space separated list of GPU indices (starting at 1, default: all):
Do you want to enable out-of-core textures on this machine?
Please enter y/n (default: n): y
/Volumes/OctaneRender Enterprise Slave 2019.1.1/install daemon: line 89: /Volumes/OctaneRender Enterprise Slave 2019.1.1/.OctaneRender Daemon *.app/Contents/MacOS/octane_slave: No such file or directory
What is the maximal amount of RAM memory which should be used (default: 0)?
Amount (gigabytes)? 12
Please confirm the entered configuration:
  Daemon Port = 48000
  GPUs        = all
  out-of-core texture memory enabled
    Maximum: 12 GB
Are the values above correct? Please enter y/n (default: y):y
Creating temporary launch script ...
Creating temporary launch agent ...
Copying bundle into /Applications and launch agent into /Library/LaunchAgents ...
32:211: execution error: Terminal got an error: cp: /Volumes/OctaneRender Enterprise Slave 2019.1.1/.OctaneRender Daemon *.app: No such file or directory (1)
Installation failed due to:
  Could not install daemon and launch agent.
Press any key to exit...
please can you fix this asap, as we urgently need this version to render out over network...
funk
BUG: Displacement causing shading normals on other materials to be faceted?
I'm running into an issue where having displacement on a material on 1 mesh, causes materials on other meshes to become faceted
1. Load the orbx and select the render target to render
NOTE: The 2 teapots look faceted
2. Disconnect the "displace%Default" material/nodegraph from the abc node
RESULT: Now the smoothing on the teapots is correct (smooth)
FrankLIU
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to clear linear 2D device memory
-> failed to load symbol data to the device(const11)
device 0: failed to upload imager params
-> failed to deallocate device memory
-> could not get memory info
Hey Zay,
If possible, can you please share your scene for debugging purpose?
Frank
Zay
FrankLIU wrote:Hey Zay,
Frank
Posted one here: viewtopic.php?p=365587#p365587
Or just add a RenderTarget. That's enough to make it crash on my Win7 box.
Note, this might be a win7 only problem as I tested it then for 2 days. Works on Win10 but not on win7.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
FrankLIU
Hey Zay,
I checked your scene uploaded and another even more complicated scene using upsampler 2x and 4x.
none of them crashed on my Win 10 machine.
It seems to be a Win 7 specific crash.
I have to find out a machine with Win 7 and take a look there
Frank
Zay
FrankLIU wrote:It seems to be a Win 7 specific crash.
Frank
It's not all win7 machines. Some has it working in win7 while some don't. My test showed it doesn't work on my win7 Pro, but if I upgraded to win10 it worked. Not even a clean Win7 Pro install could fix it.
