OctaneRender™ Standalone v1.01 (obsolete)
carbon
roeland wrote: [*]Removed priority input pin on medium node.
Just curious, will it ever be back and actually with some effect? I asked about it a couple of times without any answer. I don't want to be annoying, but this is very important for my work. It might save me many hours of modelling and also it might shift my interest back on Octane as a production tool..
Thanks for reply
c.
OSX10.6, GTX260(896MB), QuadCore@3GHz, 8GB RAM || Ubuntu10.04, 8400(display),GTX460(2GB), QuadCore@3GHz, 4GB RAM
ROUBAL
@Oguzbir : About the white balance, it looks more like a color grading than a white balance, as the color picker seems to not be usable in the render window.
I don't understand why the red increases when you reduce the red value... same for other colors. It seems to work the opposite than logic !
newske
Any chance of getting revised command line input (batching) in this release?
Octane for Rhino | Windows 8.1 x64 | i7-3820 OC | GTX970 4GB OC & GTX 560 Ti 1GB OC | 32GB DDR3
Karba
ROUBAL wrote:@Oguzbir : About the white balance, it looks more like a color grading than a white balance, as the color picker seems to not be usable in the render window.
It is quite easy to use. If you see your image has mostly blue color, just set blue color to white balance.
Daniel
That's similar to how I've used white balance on video cameras before. If something looked blue but was supposed to be white, I'd point the camera at the blue and press a button that basically said to the camera "that's supposed to be white".
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
m.arc.in
The new RC is Sensational.
File loading time in my case is much, much faster. Everything works fine. Shadow catcher is great feature, but... something is missing.
I think that in the system / kernel panel should be an option that allowed us to exchange background. For example, in this way:
If alphachannel is on, should be a possibility in addition to option "keep environment", to "replace the environment" with a bitmap.
Options may have to work interchangeably.
I think, it is not so hard to do that for you guys!
This would allow us to render the final images, without additional post production
Great Release! Keep up good work!
win7 64/core i7 920/32GB RAM/3x GTX 580 3GB 4x GTX 970 4GB/blender 2.79/Rhino 5,0/octane 3
win7 64/core i5-460M/8GB RAM/GTX 460M 1,5GB/blender 2.79/Rhino 5,0/octane 3 (ASUS G73JW)
krzychuc4d
agree with above comment
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
Elvissuperstar007
m.arc.in wrote:The new RC is Sensational.
I think that in the system / kernel panel should be an option that allowed us to the exchange background. For example, in this way:
If alphachannel is on, should be a possibility in addition to options: keep environment, to replace the environment with a bitmap.
+1000
best release
necko77
I totaly suport this idea....Every idea that decreases needed time for finalization of work is welcome !
We can make Octane Render to be polished little render devil :)
Keep on good work OR team !
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
Refracty
new glossy materials are now bluish - is this on purpose?
