Beta 2.2 RC1: 3Ds Max plugin testing thread
kilaD
n1k, im looking into it now, it may be you found a bug:)
Hello
justix
kilaD wrote:justix: You must move all the files, not only octane.exe. Copy the folder instead
I did re-install Octane directly to C:\ but the first test from it worked now it does not anymore, tried to install octane again 2 times and back to the original installation path and even if I try to load an obj it stop with this error...getting on my T..s :evil:
edit: Found that for unknown reason 3dMax2010 did kidnap the opengl driver..I believe, as I tried again without Max being open and it worked again...... :?:
still can't use the latest 0.22 RC1 as it is full of artifacts..waiting for a fix from Radiant
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
kilaD
Are you using opengl in max? dx is 10x faster
Hello
justix
kilaD wrote:Are you using opengl in max? dx is 10x faster
I think I checked it out already and it was DX but I will check again just to be on the safe side
justix
Any plans to export vray lights and materials?
Proupin
justix wrote:Any plans to export vray lights and materials?
Vray material conversion would be great!
EDIT: as I mentioned somewhere before, here you can find a free max script that converts materials from different rendering engines (Vray, MR, Maxwell, Scanline...) Perhaps it could be used as a foundation for a built-in conversion feat., or just added as part of the workflow, since it's free?
n1k
Hi kilaD:)
Did you manage to find out is it a bug in script or I'm doing something wrong? :)
n1k
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
justix
I was aware of this since early release but I don't think it convert vray lights properly if not at all, maybe i'm doing something wrong but I think that Octane does not handle Light Portal and MTL yet...or is it double dutch?
[gk]
I have already started on a material converter and a octane mat lib combined.
Octane doesnt suport anything but a direct light, the script can be altered to accept vray, brazil, any specific light as well ofcourse.
Amiga 1000 with 2mb memory card
kilaD
When arealights etc are implemented in Octane, yes
I'll look into vraymaterial conversion, shouldn't be that hard to implement
edit: ah didnt see your post Mads. I forgot pressing submit an hour ago :)
Hello
Return to “Autodesk 3Ds Max”
