Version 4.0-RC2-R1 (18.08.2018)
anklove wrote:Just had to revert to stable version since it became impossible to work on my project. I had really complex blend mat with ~15 4k+ textures and it was freezing for 10-15 sec on node editor every time i change any value. The same project works just fine on stable version.
There should not be a difference between two versions. Could you please send me a sample scene?
nscr
Hi!
Getting render failure on a scene that was working fine yesterday. Nothing has changed in the project. Here is the crash report.
Also experienced a lot of lag when making materials with large textures, others have mentioned the same issue.
Thanks!
octane 4.00 RC2 180910 101628.log
(1.24 KiB) Downloaded 389 times
nscr wrote:Hi!
Thanks!
Could you please provide some details? And a sample scene please? Otherwise it will not get fixed.
Nando_The_Fly_Design
I'm testing this version and it's very stable. Good work Aoktar. How can I use the Beauty denoiser in After Effects pass? the resulting image, like the beauty pass is very dark.
Render in C4D:
Extractor in AE:
I take advantage to share an icon for the material unviersal, if it serves you. Greetings!
Nando_The_Fly_Design wrote:I'm testing this version and it's very stable. Good work Aoktar. How can I use the Beauty denoiser in After Effects pass? the resulting image, like the beauty pass is very dark.
Thanks for icon!
You can apply gamma correction for linear results or just change tonemap type, etc.. as in picture.
Ron
Hi Achmet,
this release is great and stable on most scenes - thank you for doing such a great job!
Unfortunately on some scenes C4D shuts off completely by itself while rendering without writing a bug report. After a couple of tests I see that scenes with larger resolutions are affected (eg. 7000x4000 px at 300 dpi).
Is this a known issue?
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
nemcekmiki
In this version, each click and change in material parameter (node editor) freezes cinema for a few seconds until it updates. Dragging sliders is impossible for me. I tried to go back to V4.0-RC1.1 and it works.
Thanks!
tobydalsgaard
In this version creating Metal textures does not work at all for me. Cycled through Octane, Beckman, and GGX, played with the IORs on each, changed IOR modes and I only get white diffuse material in the texture preview as well as the live viewer. Changing the diffuse changes the color, but still not metal. Changing the roughness and the spec have no effect on the material. Restarted and still no luck, noticed this the other day but thought I was just messing something up. If I open an old project with metal textures those still work, it is only when creating new ones. Even if I try to create new metal textures next to working metal textures it does not work.
Windows 10 1803
Cinema 4D R19.068
4 x 1080tis
Nvidia 388.13 and also tried 399.24
Asus X99-10G-E-WS
cobradimond
Hi! I can confirm v4 is rendering slower than v3 at this time. Really excited about playing with this plugin. Lots of interesting things in it. Thanks for all the hard work.
right side v4 left side v3
@tobydalsgaard;
please, set the Specular Map value to 1 for the Metallic material:
@cobradimond:
the issue has been already solved in v4RC3 SDK, and the fix will be present in the next release.
ciao Beppe
