Overview of OSL Shaders in Octane
funk
rohandalvi, I was looking into photoshop blend modes for OSL and found this:
https://blendersushi.blogspot.com/2013/ ... tions.html
roeland
For this you can use the step function. step(a, b) is equivalent to a >= b but is calculated component-wise.
    color lt = step(Target, 0.5);
    c = (1 - lt) * (1 - (1-2*(Target-0.5)) * (1-Blend)) + lt * ((2*Target) * Blend);
Notiusweb
Is it possible to blur a texture, or a shader 'result', with a float?
What might that look like, in Octane-OSL
(I do not mean 'blur' as in motion blur...I am referring to, say, a Gaussian blur, aka sharpness reduction...like in Photoshop)
Thank you.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Rico_uk
Any developers we can pay to create a custom texture shader using OSL for Octane?
whersmy
roeland wrote:A basic shader for a laminate floor looks like this:
#include <octane-oslintrin.h>
shader Laminate(
    color plank1 = .3,
    color plank2 = color(0, 0, 1),
    color plank3 = color(0, 1, 0),
    color plank4 = color(0, 1, 1),
    color plank5 = color(1, 0, 0),
    color plank6 = color(1, 0, 1),
    color plank7 = color(1, 1, 0),
    color plank8 = 1,
    color plank9 = .1,
    float plankAspect = 5 [[float min = .01, float max=100, float sliderexponent=3]],
    matrix Transform = .25,
    point Projection = point(u, v, 0) [[string inputType = "projection"]],
    output color c = 0)
    int AMOUNT = 9;
    // use the projection and transform inputs
    point p = transform(1/Transform, Projection);
    float y = p[1] * plankAspect;
    // random offset for each row
    float x = p[0] + noise("cell", y, 0);
    // random plank and orientation for each cell
    float rnd = noise("cell", x, y) * AMOUNT;
    int flip = (rnd - floor(rnd)) < .5;
    // make UV mapping per cell and evaluate the right texture
    float plU = x - floor(x);
    float plV = y - floor(y);
    if (flip)
        plU = 1 - plU;
        plV = 1 - plV;
    if      (rnd < 1) { c = _evaluateDelayed(plank1, plU, plV); }
    else if (rnd < 2) { c = _evaluateDelayed(plank2, plU, plV); }
    else if (rnd < 3) { c = _evaluateDelayed(plank3, plU, plV); }
    else if (rnd < 4) { c = _evaluateDelayed(plank4, plU, plV); }
    else if (rnd < 5) { c = _evaluateDelayed(plank5, plU, plV); }
    else if (rnd < 6) { c = _evaluateDelayed(plank6, plU, plV); }
    else if (rnd < 7) { c = _evaluateDelayed(plank7, plU, plV); }
    else if (rnd < 8) { c = _evaluateDelayed(plank8, plU, plV); }
    else              { c = _evaluateDelayed(plank9, plU, plV); }
How to use: the OSL texture node node will have 9 texture inputs named plank1 to plank9. Connect each to an image texture, and for the image textures set the projection to “OSL UV”.
-Roeland
Would love to get this working, but I get the following output:
Script: [string "Script"]:1: unexpected symbol near '#'
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Notiusweb
I am able to get it to work in V4_R3 (in this case I am projecting it as an emitter onto the floor. )
But Roeland's code seems good, the OSL-language compiler accepts it.
Plugs: Enterprise
Notiusweb
This one just gives Compilation failed in Standalone V4_RC3
aoktar wrote:Doing some tests with codes from internet while improving the stuff.
simple deformation with osl_projection.
shader OslProjection
     color dist=0,
    output point uvw = 0
    uvw = 2*point(u, v, 0)+dist;
This one.... :evil:
This one leads to All GPU failed in Red.
It actually compiles fine per the OSL language compiler.
But whether I am using all 8 GPU, or just 1...they all go red! (V4_RC3)
aoktar wrote: Crazy parquet script
shader DWParquetTile (
        float DiffuseAmt = 0.75 ,
        float SpecularAmt = 0.15,
        float Roughness = 0.025,
        color SpecularColor = color(1.0),
        float RingScale = 25.0,
        float GrainScale = 55.0,
        float Grainy = 1.0,
        float Wavy = 0.08,
        float TextureScale = 5.0,
        color LightWood = color (0.57, 0.292, 0.125),
        color DarkWood  = color (0.275, 0.15, 0.06),
        color GrooveColor  = color (0.05, 0.04, 0.015),
        int PlanksPerTile = 1,
        float PlankWidth = 0.2,
        float PlankVary = 0.6,
        float GrooveWidth = 0.1,
        output color BSDF = .5 )
#define snoise(x) (2 * noise((x)) - 1)
#define boxstep(a,b,x) (clamp(((x)-(a))/((b)-(a)),0,1))
#define MINFILTERWIDTH 1.0e-7
        vector Vector = P;
    float su = Vector[0];
    float tv = Vector[1];
    float r, r2;
    point Nf;
    float whichrow, whichplank;
    float swidth, twidth, fwidth, ss, tt, w, h, fade, ttt;
    color Ct, woodcolor;
    float groovy;
    float PGWIDTH, PGHEIGHT, GWF, GHF;
    float tilewidth, whichtile, tmp, planklength;
    PGWIDTH = PlankWidth+GrooveWidth;
    planklength = PGWIDTH * PlanksPerTile - GrooveWidth;
    PGHEIGHT = planklength+GrooveWidth;
    GWF = GrooveWidth*0.05/PGWIDTH;
    GHF = GrooveWidth*0.05/PGHEIGHT;
    /* Determine how wide in s-t space one pixel projects to */
    swidth = (max (abs(Dx(su)*su) + abs(Dy(su)*tv), MINFILTERWIDTH) / PGWIDTH) * TextureScale;
    twidth = (max (abs(Dx(tv)*su) + abs(Dy(tv)*tv), MINFILTERWIDTH) / PGHEIGHT) * TextureScale;
    fwidth = max(swidth,twidth);
    ss = (TextureScale * su) / PGWIDTH;
    whichrow = floor (ss);
    tt = (TextureScale * tv) / PGHEIGHT;
    whichplank = floor(tt);
    if (mod (whichrow/PlanksPerTile + whichplank, 2) >= 1) {
        ss = TextureScale * tv / PGWIDTH;
        tt = TextureScale * su / PGHEIGHT;
        tmp = swidth;  swidth = twidth;  twidth = tmp;
    ss -= whichrow;
    tt -= whichplank;
    whichplank += 20*(whichrow+10);
     * Figure out where the grooves are.  The value groovy is 0 where there
     * are grooves, 1 where the wood grain is visible.  Do some simple
     * antialiasing.
    if (swidth >= 1)
        w = 1 - 2*GWF;
    else {
        w = clamp (boxstep(GWF-swidth,GWF,ss), max(1-GWF/swidth,0), 1)
        - clamp (boxstep(1-GWF-swidth,1-GWF,ss), 0, 2*GWF/swidth);
    if (twidth >= 1)
        h = 1 - 2*GHF;
    else {
        h = clamp (boxstep(GHF-twidth,GHF,tt), max(1-GHF/twidth,0),1)
        - clamp (boxstep(1-GHF-twidth,1-GHF,tt), 0, 2*GHF/twidth);
    /* This would be the non-antialiased version:
     * w = step (GWF,ss) - step(1-GWF,ss);
     * h = step (GHF,tt) - step(1-GHF,tt);
    groovy = w*h;
     * Add the ring patterns
    fade = smoothstep (1/RingScale, 8/RingScale, fwidth);
    if (fade < 0.999) {
        ttt = tt/4+whichplank/28.38 + Wavy * noise (8*ss, tt/4);
        r = RingScale * noise (ss-whichplank, ttt);
        r -= floor (r);
        r = 0.3 + 0.7 * smoothstep(0.2, 0.55, r) * (1 - smoothstep(0.75, 0.8, r));
        r = (1-fade)*r + 0.65*fade;
         * Multiply the ring pattern by the fine grain
        fade = smoothstep (2/GrainScale, 8/GrainScale, fwidth);
        if (fade < 0.999) {
            r2 = 1.3 - noise (ss*GrainScale, (tt*GrainScale/4));
            r2 = Grainy * r2*r2 + (1-Grainy);
            r *= (1-fade)*r2 + (0.75*fade);
        else
            r *= 0.75;
    else
        r = 0.4875;
    /* Mix the light and dark wood according to the grain pattern */
    woodcolor = mix (LightWood, DarkWood, r);
    /* Add plank-to-plank variation in overall color */
    woodcolor *= (1-PlankVary/2 + PlankVary * noise (whichplank+0.5));
    Ct = mix (GrooveColor, woodcolor, groovy);
    Nf = normalize(N);
BSDF =  Ct * DiffuseAmt;
   // BSDF = Ct * DiffuseAmt * diffuse(Nf);
  //  BSDF += SpecularColor * SpecularAmt;
Plugs: Enterprise
roeland
`Dx` and `Dy` are not implemented yet in Octane. This is unfortunately not something we can easily add.
Rik
Wow. So OSL really took off then?
Great work with all those samples.
FFS
Goldorak
Rik wrote:Wow. So OSL really took off then?
FFS
Universal camera among other 2019 features and new nodes is pure OSL. I promised you we’d bundle 100+ shaders in the 2019 release cycle, we’re doing that even if you don’t see the shader code (that’s the point - meant to be artist friendly).
I assume you’ve seen the OSL vector displacement and volume shading too in 2019.1?
