OctaneRender® 1.025 beta2.58 test release [obsolete]
Jaberwocky
roeland
I've done some more testing.
Results:
Libra office draw and write. Both paste in correctly , however alpha channel pastes in as black rather than clear.With Photoshop elements again, Alpha channel pastes in as black rather than clear.
I suspect therefore, apart from the alpha Channel problem and according to Matej's results above, that this might be a Linux system problem rather than a windows problem.
ROUBAL
Well, I have tested again the Clipboard Copy/Paste feature, and it works fine in Gimp 2.6, Photoshop Elements (a very old version), and Dogwaffle Pro 5.1 (painting program). I had done Ctrl+C over the icon instead of clicking on it ! Stupid me ! :lol:
bb3d
Thanx for this release, the new features are very welcome.
No crashes so far.
Unfortunately, the alpha transparency and parameter vanishing bugs mentioned here...
http://www.refractivesoftware.com/forum ... &start=130
... are still not fixed.
Using Octane 1.11 on Intel Core i7 3770K @ 4,4 GHz / 16GB RAM / EVGA GTX670 SC+ 4GB driver 306.97 / Win7 x64 SP1
hi, i've tested the new "copy render to clipboard" function and it works pretty well also on osx 10.7.3, thanks again roeland ;)
Edit: but i have to say that this is the more unstable version of octane that i ever try, even create a new material node make octane crash :(
roeland, if you want i can send you some crash report tomorrow ;)
roeland
Jaberwocky wrote:Libra office draw and write. Both paste in correctly , however alpha channel pastes in as black rather than clear.With Photoshop elements again, Alpha channel pastes in as black rather than clear.
Images with transparency is a non-standard clipboard format on windows. Photoshop doesn't support pasting images with transparency from other applications, GIMP and Microsoft Office do.
I tested on Linux (CentOS 5.5 64-bit) and pasting works in GIMP (including transparency) and with OpenOffice (without transparency).
Roeland
grimm
I tested copying into Gimp from the clipboard and it worked fine. This is on Fedora 15. Matej when was the last time you re-booted? Sometimes some of the desktop services die or get killed. At least I have seen this happen with Gnome on Fedora. You could try restarting X or logout and login again, or reboot and see if that helps.
matej
Hm, I booted yesterday and even after a logout it still doesn't work. Apparently it works for all of you, so it must be my system. I can live without this functionality, so no worries. :)
cgmo.net
