Activated log options can cause that. Try without that3dworks wrote:i am also increasingly having another issue in my latest project. when i am editing a material in the node editor, i often get C4D hanging while editing a node. i am only using the node editor because used to it, never do wediting in the layered material mode. when i am schanging a node or applying to a material tag, the beachball starts to spin and usually i get aplugi status like the the screenshots.
here all my octane settings as screenshots, maybe i'm doing something wrong?
Cinema 4D version 2018.1.3-R5 (Latest stable) - 07.10.2019
viewtopic.php?f=33&t=72221cmittenaere wrote:Hello,
Rtx is on ?
aoktar wrote:Activated log options can cause that. Try without that3dworks wrote:i am also increasingly having another issue in my latest project. when i am editing a material in the node editor, i often get C4D hanging while editing a node. i am only using the node editor because used to it, never do wediting in the layered material mode. when i am schanging a node or applying to a material tag, the beachball starts to spin and usually i get aplugi status like the the screenshots.
unfortunately, this is not solving the issue. but what i found out is that these node editing freezes do never happen when i edit materials of the same scene in release 4.0.4. so for now i edit all materials whith 4.0.4 then reload plugin and scene and do the other setup with 2018.1.3 - seems to render a bit faster.
Updated the builds with better R21 support. Enjoy it!
It is working great! Thanks! I appreciate some of the new node features included in this build.aoktar wrote:Updated the builds with better R21 support. Enjoy it!
However I have seen you included some of the new 2019 displacements features in the engine tab (Max subdivision level?) in 2018.3 R2 and 4.05 R3.
Wasn't this supposed to be only in 2019's build?
Cheers
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Thank you!aoktar wrote:Updated the builds with better R21 support. Enjoy it!
Yes, I forgot to remove these. I'll do in a next build. Thanks for report!Kalua wrote:It is working great! Thanks! I appreciate some of the new node features included in this build.aoktar wrote:Updated the builds with better R21 support. Enjoy it!
Cheers
- alekpanfilov
- Contact:
Thnx!
Another issue I noticed in R21: sometimes the material preview is not refreshing correctly in material manager window. I attach a small video.
Cheers
Cheers
