OctaneRender™ Standalone v1.01 (obsolete)
superb job, you're brave, all features are beatifull
best regards
octaner
Thank youuuuuu!!!
WIN 8 Pro x64 | ASUS Sabertooth x79| i7 3930k Stepping C2| EVGA GT 520 | 32GB 1600Mhz RAM
cyrillweiss
Thx for the xmas gift:)
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
jitendra
matej wrote:
jitendra wrote:
matej wrote:I hear weird noises (like scratching) from my graphic card (supposedly), during rendering when postprocessing is enabled. Should I be worried? :?
Same here..
Especially with post-processing this is an issue.
I am using gtx 590.
Hm, as of now, all of us that hear noises have 5xx line of graphic cards, but maybe we have crappy PSU's too? Mine certainly isn't top of the line and it's quite old too... :)
I have coolermaster gold 1200w PSU.
Noise is coming from GPU.
Jeet
Best Regards, Jitendra
MattRM
Nice job guys !!! Continues to this way !!!
Matt
matej
I'll be an ungrateful bastard and ask three small GUI improvements here (not worth opening a separate thread, imo):
1.) Disable changing values with the mouse wheel in the node inspector or make it "modifier" + mouse wheel. The fact that the wheel scrolls NI and changes slider values at the same time, makes it unusable, because you can never know when you'll accidentally change something while scrolling. I seriously doubt that users are accustomed to moving sliders / changing values with the wheel, so this functionality is not needed and just gets in the way.
2.) A swap x <-> y button in the resolution tab. I find myself switching between landscape and portrait resolutions very often, when searching for good shots. Currently the process is to disable aspect ratio, change x, change y, enable aspect ratio. This process could be faster if we had a button that would just swap x & y values of the resolution.
3.) Native file browser dialog. The Octane file browser is quite limited - it doesn't show image previews, you cant sort file lists, you cant add custom default paths... couldn't Octane just use system native file browser?
cgmo.net
smicha
matej wrote:I'll be an ungrateful bastard and ask three small GUI improvements here (not worth opening a separate thread, imo):
+1 or introduce similar solution that is present in 3ds max - place cursor on a value, hold LMB and drag mouse up or down to change values.
ROUBAL
+1 ! I always found the current behaviour dangerous. I sometimes destroyed a shader by accident because of this thing !
:arrow: I would also like to say that the copy value feature would be faster if we could copy the value pointed by the cursor directly without having to left-click before selecting copy with the right button or typing Ctrl-C (like in Blender). Direct copy of a color instead of 3 RGB values would be helpful and faster too.
César
I agree too. Even if the best would be undo supports to avoid mistakes.
ROUBAL
I have just had one hour free to test quickly the new Daylight system and post-pro : Very nice ! ;)
:arrow: With my Cubix Box with dedicated 750W for my two GPUs, I noticed no weird noise (post pro features enabled). The two GTX 580 3GB are running at 98-99%, and their behaviour seems to be normal.
