OctaneRender® for 3ds max® v1.0 beta 3.00b[Test]
mbetke
used it yesterday without problems...
PURE3D Visualisierungen
wxyz
Thanks. I ran an earlier version on another copy of Max and then it was ok.
petermax
is it possible to add a feature via the view port option to auto save a frame every x number of samples (for example every 1000 samples)
very useful for determining when a frame is clear for animations, also progressive saves in general... I do a lot of testing via the view port and having to save manually all the time is pain in the behind seriously, I have to save hundreds of images whilst testing, IT IS A PAIN!!... at least give us a one click save please (assign a save path with simple iteration number) :D
Win 7 64 | 3 x GTX 580 | i7 950 | 24GB
User avatar (Default)
merid888
hello, some one know use the instances in octane for max ? some video tutorial ?
regards
MaTtY631990
You need to right click on the object you want to instance and go to Octane properties and enable the movable proxy option. You can now clone your object as instances from the clone dialog.
andrian
Karba, any chance to convert vray2sided material in the upcoming release?
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
gabrielefx
waiting for the 3.0c...
merid888
thank you MaTtY631990 i'll make test with this tips
regards
RayTracey
A real-time test with MassFX:
gabrielefx
RayTracey wrote:A real-time test with MassFX:
here the mblur is necessary...
Return to “Autodesk 3Ds Max”
