OctaneRender™ Standalone 3.06 TEST 3
vijay
mikinik wrote:After changing the noise threshold during the rendering sampler does not work correctly. Shows that reached the threshold in dark areas and continues to render there where everything is clean, judging by noise passes.
If I do not change the noise threshold to the lower side, is displayed correctly.
I apologize for such a long post. :roll:
It's hard to reproduce this bug without the actual scene settings. Could you please send me the scene settings as well ?.
mikinik
vijay_thirukonda, I made a mistake. This bug is associated with the value expected exposure. I initially put a high value and during rendering it reduce. After that, it turns out this bug. I do it to adaptive sampling worked as good as the previous version. If I save the scene and open again there is no this error.
Expected exposure a very strange option, now even if I put the noise threshold 1.0 adaptive sampling with long time does not work, and the result is obtained as before without adaptive sampling, the light areas without any noise, in dark areas noisy.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
Zay
When a render is done with AS and there's still noise, is it not possible to clean it up anymore with region render?
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
enricocerica
Zay wrote:When a render is done with AS and there's still noise, is it not possible to clean it up anymore with region render?
Yes you can
http://www.myline.be
Zay
enricocerica wrote:Yes you can
Ok :) Is it too much to ask how? Cuz when the noise filter is all green nothing happens when using the region render.
Zay
Zay wrote:Ok :) Is it too much to ask how? Cuz when the noise filter is all green nothing happens when using the region render.
Ok, I found a solution. Max samples was set to max (100000), so to go higher I need to type it manually to get the rendering going again and clear the green noise filter.
kavorka
With how awesome adaptive sampling is, it would make sense to be able to set max samples to 0 and that would make it just go until it is no longer noisy.
FrankPooleFloating
I gotta tell ya, that's not a bad idea. +1
enricocerica
Mmm strange, it's not the behavior I observed in the previous version, anyway once you selected the region, you could reduce the noise threshold to force refinement as it doesn't restart the render anymore (check first ;) )
funk
Is there a reason the adaptive sampling expected exposure can't be set below 1.0? Or is this just an oversight?
Expected exposure: This should be set to the approximate exposure you plan to use in the imager.
Sometimes we use exposures below 1.0
