OctaneRender® for 3ds max® v2.23.2 - 2.2 [OBSOLETE]
boris
MustafaKaya wrote:Forest Pack materials problem. :(
confirmed. installed the newest forestpack pro version 4.4.1.
I sticked with 2_16a octane until now, I can confirm forest was working there.
it seems like this octane version can't translate the materials coming from forest. see screenshot:
edit: here the shot with 2.16a which works fine:
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
RobSteady
Seeing these black squares again in the map editor:
Jim, it's not possible to show the map there?
Asked this before, again and again...
boris
RobSteady wrote:Seeing these black squares again in the map editor:
at least make them red so we don't forget asking about it :mrgreen:
Goldisart
Often working with Orthographic Projection and function Clipping yes! octane in camera has this feature but there not Orthographic Projectio.
If I work with a standard camera that every time I have to change the value of the clipping of general options.
please enter a support Orthographic Projection in octane 3dmaks camera or full support for standard camera with additional features
Elvissuperstar007
Goldisart wrote:Often working with Orthographic Projection and function Clipping yes! octane in camera has this feature but there not Orthographic Projectio.
+100000
vfxman83
hi JimStar;
When the octane convert tool supports Vray2sided material and 3ds max tiles map these mats are important but doesn't work
and the material editor hdris are don't see
when will you or octane team fix this problem ?
Thank you.
RobSteady
Hey Jim, any updates soon? What's the progress?
Please involve the customers!
vfxman83
The octane doesn't convert vray 2 sided material is there any way to fix this problem or when it will be update
it is very important that
in this case same problem with 3ds max standart bitmap tiles too.
gabrielefx
all Vray glossy materials are converted with ior set to 1...and I don't understand why
also translucent Vray materials are wrong converted.
I tweak all the converted materials
If I am a programmer....
darkline
One bug I am noticing, is the octane viewport freezes often if you adjust many parameters on the fly (especially if you hit 0 values)
For example, rotate the texture environment map by spinning the value up and down, if you hit zero, the render viewport completely freezes. I have to close it and re-open it for the viewport to become interactive again.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
Locked
