Spdo wrote:Karba wrote:So what can i do ?Spdo wrote:Hi Kabra when the render elements acvtive the octane render viewport says render is failed
Where can we use render elements save in the re menu or use standart render f9 on the 3ds max
What is the best way ?
Thank you.
You are out of gpu memory. look at memory statistic.
Have you tried to add all the instance objects on the model as movable proxies on the octane object properties? This will make octane recognize them as proxies and reduce mem usage. The scenes need to be optimized in order to fit the Vram.
You can also not use the main gcard as some of the vram is being used by the system resulting in less vram available for octane.
