OctaneRender® for 3ds max® v2.11.1
muski
Spdo wrote:
Karba wrote:
Spdo wrote:Hi Kabra when the render elements acvtive the octane render viewport says render is failed
Where can we use render elements save in the re menu or use standart render f9 on the 3ds max
What is the best way ?
Thank you.
You are out of gpu memory. look at memory statistic.
So what can i do ?
Have you tried to add all the instance objects on the model as movable proxies on the octane object properties? This will make octane recognize them as proxies and reduce mem usage. The scenes need to be optimized in order to fit the Vram.
You can also not use the main gcard as some of the vram is being used by the system resulting in less vram available for octane.
using octane since the dawn of the dinosaurs :)
coilbook
Hi Karba were you able add that static noise button or it will be in the new release
Thank you
dawe
Not sure if this is a max issue or octane: It seems like the elements get clamped. only the beauty pass is unclamped. I have tried tif, exr and hdr.
//Daniel
Karba
dawe wrote:Not sure if this is a max issue or octane: It seems like the elements get clamped. only the beauty pass is unclamped. I have tried tif, exr and hdr.
//Daniel
Fixed, what for a next release
Karba
HHbomb wrote:I can't manage to make a render region in octane viewport with netrender. Is it a bug ? or an octane limitation ?
When region is active the render continue but the viewport is not updated. :cry:
That should work, just tested. The only issue is network rendering can't keep images around region render it get corrupted.
mykola1985
Hi Karba, i left rendering for the whole night with this version, NO CRASHES AT ALL!!! ;) THANK YOU!!! please don't forget static noise!
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
Karba
mykola1985 wrote:Hi Karba, i left rendering for the whole night with this version, NO CRASHES AT ALL!!! ;) THANK YOU!!! please don't forget static noise!
I will make a new release with static noise option today.
coilbook
same here a lot more stable than previous versions
DP
Hi Karba,
I migrated from Win 7 to Win 10 and after that the button "port to max framebuffer" DOESN't work with v.2.04 3ds max plugin, it doesn't open any window like before with win 7.
I upgraded to v.2.24.2 - 2.10 for 3ds max and still doesn't work.
Please any suggestion ? I'm in a hurry with a job
Thanks in advance
Joe
Jorgensen
does this version not support 3ds max 2016? it's not listed in the installer.
EDIT
Ahh i thought this was the newest version, 2.11, but it's from 2014..... sorry.
/thanks
Locked
Return to “Releases”
