 Thanks, I'm going to try it right now!
That problem was fixed, I updated the downloads in the original post.Daniel79 wrote:I got a feeling that this new release is just to appease ... they have not even tested! very unstable, when I press "preview configuration" crash!
"google traslate":D
I can't reproduce the environment issue here. Are you talking about saving in 2.57 and loading in 2.58? What kind of file do you use for HDR?ROUBAL wrote:Added to that, I encountered a file format error on textures in ocs files made with the previous release... The hdr environment is not loaded.
I also want to report a problem that already occured on previous releases : after loading a mesh, if you just click on the mesh node, nothing happens in most cases on big scenes (small scenes seem to work fine), and sometimes a crash occurs. To make sure that the render will start, it is necessary to keep the left mouse key pressed until the render actually starts in the render window.
