OctaneRender for DAZ Studio 2025.2.1 - 403 [OBSOLETE]
Moderator: BK
filipe_sheepwolf
Sorel wrote: Fri Aug 08, 2025 9:53 pm
filipe_sheepwolf wrote: Fri Aug 08, 2025 5:14 pm Hello.
Is the "TEMPLATING" feature not working? It refuses to load textures from the Iray materials, even after I choose one in the "primary source" option (same for "alternate" and "fallback" options)
I even tried using the Octane Render Kit collection available in the Daz store, but the materials it comes with just don't work either (the ones with the TEMPLATING feature just show a black or white texture, even though they should be loading the textures from the original objects they're applied to)
So far it's not working with any figure (g8, g9) or prop I tried...
Templating is working on my end. Can you post some screenshots?
Thank you for replying! Also... I was just preparing some screenshots to show you, while testing this feature on a new scene, and guess what... I figured out why it wasn't working before... I'm actually glad to know it was my fault this time! 😅
So yeah, it works as intended now, thank you for the help! 😜
SiliconAya
BK wrote: Wed Jul 23, 2025 1:52 am
SiliconAya wrote: Sun Jul 20, 2025 4:05 am
BK wrote: Wed Jul 02, 2025 8:45 pm
Hi SiliconAya ,
Thank you so much for reporting this.
We are unable to replicate the crash on our side.
Would you happen to remember the steps and was there any AOV enabled from the interactive viewport.
Cheers
I just got this crash again, exact same exception error message, (I think I've had it a few times now), the crash just seems to happen, it's not consistent with any one activity, this time rather than panning the camera, I was adjusting the pose (bone) of G8Fs leg.
I don't believe any AOVs where enabled, it's happened in a number of both new and old scenes and I haven't touched AOVs in any of them.
Hi SiliconAya ,
Thanks for the post. We are still unable to replicate the crash with G8Fs and G8.1Fs character..
Does Daz show any popup after the crash? Please send us the logs
cheers
I've managed to save 2 crash dumps now, do you want me to DM them to you?
BK
SiliconAya wrote: Mon Aug 11, 2025 7:45 am
Hi SiliconAya ,
cheers
Hi SiliconAya ,
Thank you for the post. Yes, please DM me the crash dumps.
cheers
Kind Regards
bk3d
Sorel
Another issue I've been having, seems to be Related to textures that use the layered image editor in daz. When initially applying a L.I.E texture it loads fine, I set up the shader, etc. however the nest time I open the file the diffuse part of the texture has been replaced by the normals texture. Specifically this happens every time with Genesis 9 eye textures from the base pack.
BK
Sorel wrote: Tue Aug 19, 2025 3:29 pm Another issue I've been having, seems to be Related to textures that use the layered image editor in daz. When initially applying a L.I.E texture it loads fine, I set up the shader, etc. however the nest time I open the file the diffuse part of the texture has been replaced by the normals texture. Specifically this happens every time with Genesis 9 eye textures from the base pack.
Hi Sorel,
Would you please share the steps to replicate?
Are you using Male G9 or Female's eye?
cheers
Kind Regards
bk3d
Sorel
BK wrote: Wed Aug 20, 2025 2:40 am
Hi Sorel,
cheers
Sure. The easiest way is to load the base genesis 9 model (not the dev one). Start to render and you will see the eye textures work fine. Save the scene. Then load the scene again and start to render and you will see the diffuse texture will be replaced by the normal map texture.
BK
Sorel wrote: Wed Aug 20, 2025 2:34 pm
Hi Sorel,
cheers
Hi Sorel,
Thank you so much for the steps.
We can replicate the issue on our side.
Hope we can fix it asap!!
cheers
Kind Regards
bk3d
Sorel
Hi team it's been a while, any updates on the way?
Hun73rdk_1
Sorel wrote: Wed Oct 22, 2025 4:58 pm Hi team it's been a while, any updates on the way?
Yea no clue whats going on they dont answer on discord either
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
gaazsi
good luck :roll:
Return to “DAZ Studio”
