Cinema4D version 2023.1-Beta1-[R1] 20.07.2023
When working with UDIM tiles (8k maps), i've encountered huge slowdowns/freezes, even when just modifying other parameters in the material. I've attached a zip with all the files generated by the crash and a video of the wierd slowdowns. oct.dat was removed to regenerate a clean file but it didn't help.
- Attachments
- Cinema_4D_6LnOCeRgxP.mp4
- (21.5 MiB) Downloaded 2284 times
- node_editor_crash.zip
- Node Editor crash
- (6.07 MiB) Downloaded 136 times
Very strange black and white artifacts appear when light beams are turned on and the temperature is less than 1800~
- Attachments
- 2023-07-03 23-09-38.mp4
- (2.99 MiB) Downloaded 2221 times
Check my past posts. I reported some similar behavior - instead of power, I was playing with size and there was a threshold that glitched just like your example with analytic lights.krisclemson wrote:Power increase 15 of above glitches it out.
At least I see it is a consistent issue.
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
It seems like you have wrong parameter while using SDF in Octane plugin : "The VDB file in the ORBX file has the wrong data in it, it is a fog volume instead of a signed distance field. (in technical terms, it has 0 density outside the object and positive density inside it)."aoktar wrote:It is not a thing I am working on.SSmolak wrote:SDF still buggy here like in 2022 ver :
This issue is reproducible in Standalone but only when exported from C4D.
Blend parameter for denoiser doesn't work.
Must be very random thing.SSmolak wrote:Blend parameter for denoiser doesn't work.
It's working here with all kernels (except PMC which doesn't support it).
Could you send me your project?ShivaMist wrote:When working with UDIM tiles (8k maps), i've encountered huge slowdowns/freezes, even when just modifying other parameters in the material. I've attached a zip with all the files generated by the crash and a video of the wierd slowdowns. oct.dat was removed to regenerate a clean file but it didn't help.
Solo Node is not working on the Standard Material if Transmission = 1, any value under 1 will display it correctly. I suspect that the diffuse filter is not "active" if the material is fully transmissive.
- Attachments
- Cinema_4D_PMs0VyQ3H0.mp4
- (15.72 MiB) Downloaded 2069 times
- LOVEXMEDIA
When adding a the Flakes node in the Custom Patterns section, I get a freeze and then a crash. I'm on the latest version of C4D, 2023.2.2. I have experienced any other major issues and have gotten great render speeds so I am excited for what's to come!
- Attachments
- This is what the node looks like after C4D has crashed.
- image_2023-07-06_220256319.png (7.16 KiB) Viewed 3011 times
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
