Cinema4D version 2023.1-Beta1-[R1] 20.07.2023
Hi all,
This is a Test plugin build based on 2023.1 Beta 1 SDK. There are still missing parts of new features and this is an experimental build. So we advise to not use this release for production purposes. Anyway any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2023.1 Beta 1.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2023.1 Beta 1 [R1] plugin revisions
  • Most of the new features of Octane 2023.1, but we still have uncomplete nodes/features. They will be implemented on next builds
WINDOWS STUDIO+ BUILD (R19-R2023)
https://render.otoy.com/customerdownloa ... R1_win.rar
WINDOWS STUDIO+ DEMO BUILD (R19-R2023)
https://render.otoy.com/plugindownloads ... R1_win.rar
Mac OSX Prime BUILD (R25-R26/R2023)
Not available yet...
Please note the macOS build below will only work correctly on macOS 12.3.1 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
eyeonestudio
Thank You Ahmet. 2023.1 :)
SSmolak
Excellent, thank you for hard work !
ShivaMist
Thanks for the release! Analytics light are great :)
Amaterasu
What's going on with the analyst light? Why does it work so badly, maybe I'm doing something wrong, I didn't have this problem in Standalone
2023-06-29 18-00-19.mp4
(8.62 MiB) Downloaded 13213 times
twik25
Hi Ahmet,
Thank you for this! A few questions:
1. Looks like there is a limit of 4 Analytic Lights with light beams, is this correct? I know there is a limit to 8 analytic lights for now.
2. It appears that primitive lights are facing the wrong direction on the z axis when using area shape of Disc.
3. Is there any way you can build in a "fake" visible light solution? See attached. I would love to be able to not have to duplicate lights, and disable Visible on diffuse, specualar, and cast shadows to have visible lights. In an ideal world, there would be a "Fake Visible Light" section, so that we can control brightness and color.
4. I was able to save denoised passes with this on C4D 2023.2 with "show passes" on. So this appears to fix the stuck on displaying passes issue that has been 2022.1 and Cinema 2023.2, at least on my end.
Thanks again for your hard work.
eyeonestudio
Small Bug : Light > Spread Angle : Can't drag Slider, Input field is Ok.
Kalua
twik25 wrote:Hi Ahmet,
That seems to be the case: I also have up to 4 lights contributing to FOG.
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua
Thanks for the update, Aoktar!
Lots of new things coming up!
Some things I found are not working properly yet:
1. Lights ID numbering are incorrect?
2. With Analytic Parameters: I can't slide the Spread Angle with mouse clicked over the slider itself,only with omouse clicked over the number (C4D R2023).
Regards and thanks again!
SSmolak
Highly unstable. Hard freezes very often during simple scene manipulating with one object.
