FantasticDomenicozzo wrote:Thank you for the Fix: LV resizing problems, Ahmet, this version runs smooth like silk on Beren Saat's skin.
Cinema 4D version 2018.1.1-R2 (Obsolete stable) - 19.04.2019
2018.1 only supports 2x GPUs if you have a subscription license.momade wrote:momade wrote:Hi aoktar.
Today I got my upgraded computer back and reinstalled everything. Also I am new to a 2018 license and I am wondering, why I can not activate my GTX970 and GTX780.
A: It is because I dont understand my license?
B: Was my PC hardware messed up in the PC store while upgrading and transitioning my system to a new case and new motherboard?
C: Does 2018 not support certain GPU architectures?
So many questions I am so confused...
Anyone any thoughts on this?
I think deadlocks happen with R20.059, but fine with R20.057. I'm still investigating! It's frustrating!Kalua wrote:Yes. Maybe. I rolled back to R3 and I´m getting half the bugs> I´m currently working on a very heavy scene so it contributes a bit. I also PMed Aoktar to explaiin it.Iceman9 wrote: I'm running the latest c4d version here with no issues. Maybe it's related to some other plugins in your system? Or perhaps you are using some combination of features I've not yet used. Hope you get it sorted out.
- kurzemnieks
I'm experiencing a lot of crashes connected to OpenGL previews of materials. As soon as i turn it off, it works perfectly. Also material preview generation quite often freezes C4d. If I turn that also off, no crashes at all.
C4D version?kurzemnieks wrote:I'm experiencing a lot of crashes connected to OpenGL previews of materials. As soon as i turn it off, it works perfectly. Also material preview generation quite often freezes C4d. If I turn that also off, no crashes at all.
OS?
Hardware?
Driver?
Important warning
For OSX users with deadlock/hang issues, please try with OFF on "Synchronization on geometry updates" option. This was not required until 2018.1 for V4, but seems like Maxon done some revisions and it affects our stability.
Also for R20.059 Windows users,
I found that plugin is falling to issues which are similar deadlocks or crashes. So I've updated used C4D SDK to 20.055 and problem has been fixed. I'll make a quick release for this HOTFIX.
When I open Cinema 4D for second time or change a material in the scene I get an error with the 2018.1.1 R2. It does not let me work. I remove all the plugins and just keep Octane and the error still happening.
It doesn't happen with version 4.04
Cinema 4D R20.059
Octane Render 2018.1.1-R2
Windows 10 Pro 1809
Nvida Creator Drivers
2x 2080TI
Videos:
https://streamable.com/cjy23
https://streamable.com/8mwdf
Cinema 4D R20.059
Windows 10 Pro 1809
2x 2080TI
Videos:
Can I see the bugreport.zip pls?raulofs wrote:When I open Cinema 4D for second time or change a material in the scene I get an error with the 2018.1.1 R2. It does not let me work. I remove all the plugins and just keep Octane and the error still happening.
Cinema 4D R20.059
Windows 10 Pro 1809
2x 2080TI
Videos:
aoktar wrote:Can I see the bugreport.zip pls?raulofs wrote:When I open Cinema 4D for second time or change a material in the scene I get an error with the 2018.1.1 R2. It does not let me work. I remove all the plugins and just keep Octane and the error still happening.
Cinema 4D R20.059
Windows 10 Pro 1809
2x 2080TI
Videos:
- Attachments
- _BugReport.zip
- (95.03 KiB) Downloaded 290 times
Also please activate all log option for scene and send me c4doctanelog.txt after that.raulofs wrote:aoktar wrote:Can I see the bugreport.zip pls?raulofs wrote:When I open Cinema 4D for second time or change a material in the scene I get an error with the 2018.1.1 R2. It does not let me work. I remove all the plugins and just keep Octane and the error still happening.
Cinema 4D R20.059
Windows 10 Pro 1809
2x 2080TI
Videos:
