new features of 3.07
- enricocerica
- Contact:
Will it be possible to define the instance IDs in the csv file used to scatter the instances ?
http://www.myline.be
Hi Enrico,
yes sure, from the release notes of 3.07 test3:
ciao beppeAdded support for the definition of user instance IDs in .csv files, by introducing an (optional) header with matrix columns M00 to M23 and an instance ID column ID.
- enricocerica
- Contact:
Oups, how could I have missed thisbepeg4d wrote:Hi Enrico,
yes sure, from the release notes of 3.07 test3:ciao beppeAdded support for the definition of user instance IDs in .csv files, by introducing an (optional) header with matrix columns M00 to M23 and an instance ID column ID.
Thansk
Hi Filipe,
here it works as expected with Placement and Scatter nodes: ciao beppe
Hi Filipe,
no problem, here is the Win 7 version: please, try with the attached scene: Could it possible that the center of your objects is far away from the object location?
Did you tried to switch from World to Local mode, to see if you have differences?
