new features of 3.07
enricocerica
Will it be possible to define the instance IDs in the csv file used to scatter the instances ?
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
Hi Enrico,
yes sure, from the release notes of 3.07 test3:
Added support for the definition of user instance IDs in .csv files, by introducing an (optional) header with matrix columns M00 to M23 and an instance ID column ID.
ciao beppe
enricocerica
bepeg4d wrote:Hi Enrico,
ciao beppe
Oups, how could I have missed this :oops:
Thansk ;)
rrbarb
OctaneTeam - ThankYou!
./rrb
manalokos
I cannot see any transformation gizmos in TEST4, is it fixed? Doesn't seem to work...
Hi Filipe,
here it works as expected with Placement and Scatter nodes:
ciao beppe
manalokos
Dear Beppe,
I have tried with placements and scatter nodes and could not make any Gizmos appear, in your example I see you are using Mac, I am using windows 7.
Hi Filipe,
no problem, here is the Win 7 version:
please, try with the attached scene:
boxChairs_Gizmo.orbx
Could it possible that the center of your objects is far away from the object location?
Did you tried to switch from World to Local mode, to see if you have differences?
ciao beppe
manalokos
Yes I tried everything.
I am using windows 7 and GTX 1080ti, could it be a driver problem?
manalokos
I tried your scene and it works.
I have to check what is wrong with my scenes.
Thanks for your help!
Kind regards
Filipe
Return to “Commercial Product News & Releases (Download here)”
