CINEMA4D process going to background after closing
mtb_mike
Yes, it does work! Thank you! Now my customization changes are being saved.
Thanks again
iMac 4.2 GHz 40GB RAM | OS 10.13.6 C4D r20 Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
mtb_mike wrote:Yes, it does work! Thank you! Now my customization changes are being saved.
Thanks again
Thanks! Anyone else? Keeping the track of your posts will help the community ;)
chrisfranklin6002
I'm getting exactly the same!! Only since updating to the latest version.
chrisfranklin6002 wrote:I'm getting exactly the same!! Only since updating to the latest version.
Do you mean that's fine with 3.06.2 anymore?
MarioVisuals
Hi Aoktar,
negative it's not fine, it stays in the background.
I had problems logging out and in different machines yesterday because of that.
Windows 10 Pro 64-bit / Intel Xeon E5 v3 @ 2.40GHz x 2 / 64 GB RAM / Z10PE-D8 WS / 3 x EVGA GTX 980Ti / C4D R17 / X-Particles 3.5 / Octane 3
MarioVisuals wrote:Hi Aoktar,
Be sure you tried with 3.06.2 because it's absolutely fixed on octane plugin side. It should be depended to anothet plugin if you still have issues.
Hi MarioVisuals,
the issue with deactivation that you have encountered yesterday was caused by the SSO server, not from plugin, so the issue should be completely solved now.
Happy Rendering,
MarioVisuals
Thanks!
