CINEMA4D process going to background after closing
Rrock
Hi guys, i have a small but terrible issue:
After manually closing c4d, the UI is closing, but process still stacks at the background processes and takes around 500MB of RAM. So i can't open cinema4d later without manually killing process through task manager.
Without Octane plugin installed everything works fine.
Windows 10 64-bit.
Last build of c4doctane.
CINEMA4D R17.053
Have you tried with just Octane plugin without others? And is it 3.04.1? And is this happening everytimes?
Rrock
aoktar, i tried with others but without octane. Yes, this is 3.04.1, and yes, everytimes.
Rrock wrote:aoktar, i tried with others but without octane.
I asked for opposite of it. What happens on case? And do you have TFD?
Rrock
Tried to launch c4d with only octane installed - same result. Removed octane from plugins folder(folder is empty now) - c4d closing normally.
Yes i have TFD.
KeeWe
Same setup (latest octane and latest TFD) and same problem here. I always thought it was c4d related and didn't care too much about it. But interesting it might be Octane related.
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
grain
I have this as well, C4D process doesn't completely stop and holds onto a lot of ram until I kill it via Task Manager.
mrom
same! R16, latest octane
edit: but not all the time!
Ok i know. But i happen on me with TFD. Pls try without TFD and give me more info.
Rrock
aoktar wrote:Ok i know. But i happen on me with TFD. Pls try without TFD and give me more info.
Tried without TFD - problem is still here.
