Yes, it does work! Thank you! Now my customization changes are being saved.
Thanks again
CINEMA4D process going to background after closing
Thanks! Anyone else? Keeping the track of your posts will help the communitymtb_mike wrote:Yes, it does work! Thank you! Now my customization changes are being saved.
Thanks again
- chrisfranklin6002
I'm getting exactly the same!! Only since updating to the latest version.
Do you mean that's fine with 3.06.2 anymore?chrisfranklin6002 wrote:I'm getting exactly the same!! Only since updating to the latest version.
- MarioVisuals
Hi Aoktar,
negative it's not fine, it stays in the background.
I had problems logging out and in different machines yesterday because of that.
Windows 10 Pro 64-bit / Intel Xeon E5 v3 @ 2.40GHz x 2 / 64 GB RAM / Z10PE-D8 WS / 3 x EVGA GTX 980Ti / C4D R17 / X-Particles 3.5 / Octane 3
Be sure you tried with 3.06.2 because it's absolutely fixed on octane plugin side. It should be depended to anothet plugin if you still have issues.MarioVisuals wrote:Hi Aoktar,
Hi MarioVisuals,
the issue with deactivation that you have encountered yesterday was caused by the SSO server, not from plugin, so the issue should be completely solved now.
Happy Rendering,
ciao beppe
Happy Rendering,
ciao beppe
- MarioVisuals
