OctaneRender™ Standalone 3.03.4
Zay
I can't get displacement maps to work in "mix materials".
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
eyeonestudio
haze wrote:eyeonestudio: are you able to share an orbx for me to take a look?
I send Private Msg. Thanks.... :P
enricocerica
Zay wrote:I can't get displacement maps to work in "mix materials".
Just in case you didn't notice that, when using mix materials, you shouldn't set displacement on individual material, look in the bottom on the material settings, you have to set the displacement on this param.
http://www.myline.be
Zay
enricocerica wrote:Just in case you didn't notice that, when using mix materials, you shouldn't set displacement on individual material, look in the bottom on the material settings, you have to set the displacement on this param.
Didn't see that. Unfortunately i need both. But thanks for the heads up!
Buraq
Normaly Stanalone works fine with me but when I export scene from 3d Max, stanalone buttons turn deactive. Is something wrog?
paride4331
Hi Buraq,
I tried exporting a scene from octane 3ds max (v3.02 - 3.17) and (v3.03.4 - 4.17)
to octane stand alone and everything seems to work fine.
It could be a hardware problem and / or drivers.
What kind of hardware do you have? What about the drivers ?
Regards
Paride
Buraq
paride4331 wrote:Hi Buraq,
Regards
Paride
Thank you for your tip! I was using Nvdia 372.54 driver, after your post I loaded 372.70 version and works well :D now. I think we shouldn't blame Octane Render all time ;)
Zay
Buraq wrote:Hi,
I have seen this too loading older version scenes into Standalone. Save and then reload got the buttons back (using driver 358.50) .
oguzbir
I want to report a bug.
I want to make random looking instance objects.
The example is from MAX latest plugin. But it act the same in SA via exporting to orbx...
Problem is using Random Color Tex as mix Amount doesnot work with multi sub Material ID's
It works in simple material setup like this.
But if I want to add more detail to it I want to make same effect with muti-ID materials.
Below objects have different Material ID's on every polygon. Here I didn't use the Random Color Tex as mix Amount yet
Result is
But when I want to make it more detail I want to randomize between two separate Material ID's.
Please let us know if you can fix this.
EDIT: Original bug report: viewtopic.php?f=81&t=56487&p=289814#p289814
My Portfolio
coilbook
oguzbir wrote:I want to report a bug.
Result is
i noticed if you clone them too close to each other they do not get much random for some reason. i guess octane uses distance to decide a color?
