OctaneRender 3 for ArchiCAD [OBSOLETE]
Daniel_Ward
HI Paul,
usually when I get a crash, the whole system just freezes and I have to do a hard reset to get going again. I'm not sure a dump report exists in that situation?
I had a system freeze not long after making the post, ironically. I had 3 copies of AC20 and 2 copies of AC19 running. I was rendering on one of the AC19 projects at the time and watching something on YouTube, which possibly wasn't a great idea.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
A complete system fresh would either be a hardware issue, or you have run out of RAM.
This would take a lot of system resources, so sounds more like a "running out of RAM" issue to me.
I have updated the installers at the top of this thread with:
3.4.1.67
- Compiled with Octane 3.04.1
- Fixed issue where the AO Texture could not be disconnected
3.4.3.68
- Compiled with Octane 3.04.3
- Resolved issue where loading OCS/ORBX proxies was not working unless there was a Geometry Out node in the proxy being loaded.
3.4.4.68
- Compiled with Octane 3.04.4
I have updated the AC20 installer link at the top of this thread. It was linked to an older installer, and is now linked to 3.4.4.68.
Daniel_Ward
Hi Paul,
if you could update the AC Plug-ins to 3.04.5 would be great.
Cheers, Dan.
3.4.5.68
- Compiled with Octane 3.04.5
Daniel_Ward
Hi Paul,
do you know if the new rounded edges support in the 3.05 will work with the AC Plugin?
Cheers, Dan.
Hi Dan.
The current Octane round edges functionality requires welded vertices on the edge being rounded - however ArchiCAD generally has unwelded vertices where two surfaces join, the edge rounding will not work.
