OctaneRender 3 for ArchiCAD [OBSOLETE]
Forums: OctaneRender 3 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Re: OctaneRender 3 for ArchiCAD [TEST and STABLE]
Postby Daniel_Ward » Fri Oct 21, 2016 3:33 am
Daniel_Ward Fri Oct 21, 2016 3:33 am
HI Paul,
usually when I get a crash, the whole system just freezes and I have to do a hard reset to get going again. I'm not sure a dump report exists in that situation?
I had a system freeze not long after making the post, ironically. I had 3 copies of AC20 and 2 copies of AC19 running. I was rendering on one of the AC19 projects at the time and watching something on YouTube, which possibly wasn't a great idea.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Daniel_Ward
Postby face_off » Fri Oct 21, 2016 10:07 pm
face_off Fri Oct 21, 2016 10:07 pm
A complete system fresh would either be a hardware issue, or you have run out of RAM.
This would take a lot of system resources, so sounds more like a "running out of RAM" issue to me.
Postby face_off » Sat Oct 22, 2016 11:59 pm
face_off Sat Oct 22, 2016 11:59 pm
I have updated the installers at the top of this thread with:
3.4.1.67
- Compiled with Octane 3.04.1
- Fixed issue where the AO Texture could not be disconnected
Postby face_off » Wed Nov 02, 2016 10:38 pm
face_off Wed Nov 02, 2016 10:38 pm
3.4.3.68
- Compiled with Octane 3.04.3
- Resolved issue where loading OCS/ORBX proxies was not working unless there was a Geometry Out node in the proxy being loaded.
Postby face_off » Wed Nov 16, 2016 12:18 am
face_off Wed Nov 16, 2016 12:18 am
3.4.4.68
- Compiled with Octane 3.04.4
Postby face_off » Thu Nov 17, 2016 10:44 am
face_off Thu Nov 17, 2016 10:44 am
I have updated the AC20 installer link at the top of this thread. It was linked to an older installer, and is now linked to 3.4.4.68.
Postby Daniel_Ward » Sun Nov 27, 2016 7:38 pm
Daniel_Ward Sun Nov 27, 2016 7:38 pm
Hi Paul,
if you could update the AC Plug-ins to 3.04.5 would be great.
Cheers, Dan.
Daniel_Ward
Postby face_off » Mon Nov 28, 2016 1:29 am
face_off Mon Nov 28, 2016 1:29 am
3.4.5.68
- Compiled with Octane 3.04.5
Postby Daniel_Ward » Sun Dec 04, 2016 4:47 am
Daniel_Ward Sun Dec 04, 2016 4:47 am
Hi Paul,
do you know if the new rounded edges support in the 3.05 will work with the AC Plugin?
Cheers, Dan.
Daniel_Ward
Postby face_off » Sun Dec 04, 2016 10:37 am
face_off Sun Dec 04, 2016 10:37 am
Hi Dan.
The current Octane round edges functionality requires welded vertices on the edge being rounded - however ArchiCAD generally has unwelded vertices where two surfaces join, the edge rounding will not work.
PreviousNext
Return to Graphisoft ArchiCAD
Users browsing this forum: No registered users and 11 guests
Thu Apr 25, 2024 12:36 am [ UTC ]
