OctaneRender™ Standalone 2.25
abstrax
nuno1980 wrote:
smicha wrote:1 000 000 is not enough Nuno? :shock: :roll: :roll: :roll:
Probably yes at our sun but if we get still noises then we try more spp. ;)
As I said, it's technically not possible. You can render multiple images and stack them later if you really want to spend rendering weeks on one image.
nuno1980
abstrax wrote:As I said, it's technically not possible. You can render multiple images and stack them later if you really want to spend rendering weeks on one image.
Ok. Multi-region? If you respond me "no" then I ask how do I do multi-image.
Is multi-region for v3 only? I'm waiting good caustics at multi-region until v3.1 released, ok?
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
ivankio
abstrax wrote:
blackshore wrote:When are you adding pascal support for 2.x (1000 series)?
The Cuda Toolkit 8 is already out. Is it not just to recompile with the new tool-kit?
Will do that next week.
That is so cool! Does this http://www.videocardbenchmark.net/directCompute.html show a reasonable relative performance to expect?
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
abstrax
Version 3 currently doesn't support multiple render regions. We are planning to add adaptive sampling which would take care of the problem more or less automatically, but works only with the path tracing and direct lighting kernels. Since you are a PMC geek, it wouldn't help you. When that is done we will have a think about PMC and see if we can implement something like adaptive sampling to PMC, too. If not, we will check how much work a multi-region rendering system would be.
nuno1980
abstrax wrote:Version 3 currently doesn't support multiple render regions. We are planning to add adaptive sampling which would take care of the problem more or less automatically, but works only with the path tracing and direct lighting kernels. Since you are a PMC geek, it wouldn't help you. When that is done we will have a think about PMC and see if we can implement something like adaptive sampling to PMC, too. If not, we will check how much work a multi-region rendering system would be.
Thank you. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
