OctaneRender® for 3ds max® v2.23.2 - 2.2 [OBSOLETE]
petermax
daniel.reutersward wrote:
petermax wrote:can I get a response ideally from someone official please, a testing the Titan Xs and can't render anything in Octane, they will very rarely show under devices, what causes this??
I received a response from support, but they didn' t answer the question as to to why the cards hardly ever show under devices!
I need to get this to work soon, so a little help would be appreciated please!
thanks
I´m not anyone official but I had the same problem. What I had to do was to disable the onboard/integrated graphics on my motherboard and now everything works as it should.
If you have integrated graphics on your motherboard it could be worth trying to disable it?
thanks, will look into this, an answer at least from the community
Have to say though Otoy support has been terrible, no word on the forums, no reply via email support after 7 days, no reply from Jim, no phone contact number... just hope you'll never need Otoy support guys!
Win 7 64 | 3 x GTX 580 | i7 950 | 24GB
RobSteady
Summer break?
gabrielefx
Hi Jim,
regarding the compatibility for previous 2.0 do you mean Octane release version or your Max version?
It's a little bit confusing because Octane release is 2.23.2 and your plugin is 2.2
Could you add some letters: A, B, C, etc..., or add day,month, year?
for example:
2.32.2_A
2.32.2_B
2.32.2_C
or
2.32.2_25072015
thank you.
gabrielefx
Hi Jim,
could you add a switch to toggle the sun texture on-off? I have to create two suns and swap them.
Also I need a filter switch to toggle on-off the displacements in the render panel.
thank you.
Elvissuperstar007
Please add the function to the source, the light at both sides
Goldisart
not working
Elvissuperstar007
octane does not understand the new physical camera in 3ds max 2016
render and the real configuration of the new cameras are not comparable
octane does not understand the perspective match in 3ds max 2016
dancing with a tambourine, octane camera
OK!
OK!
Goldisart
don't know what it is but probably a mistake
Goldisart
and I also would like to obtain a square grid without longitudinal lines
nd good to have the option of setting the thickness of the lines
boris
postprocessing bloom does not work correct in stereo cube maps. probably need to alter the algorithm for cube maps.. :)
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
Locked
