Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
maestro
robotnik wrote:I had the same problem until I copied the octane.dat, vcomp100.dll and octane.dll in the C4D R15 folder. I copied those files from the directory libs64. After doing that it started normally without any problem. Hope it will work for you. I'm using Win 8.1. Cheers
Where I had only not copied, nothing helps when you start at the moment of connection and activation verification Octane server Cinema 4D crash! Without a network connection Cinema 4D is loaded, once again I turn on the Internet connection press the Octane button activation, wrote to me, "Your plugin Account is activated! After I choose Octane material and Cinema 4D crash and not react, that's all!
SVITAdmin
aoktar wrote:
SVITAdmin wrote: Odd. I have 1.0RC working great on a fairly complex scene on Mac. And I have tons of plugins on my Mac, but i wonder if a certain plugin is causing an issue on his end
weird, maybe a Os version problem also. Only problem was opengl previews for mixmaterial and have to disable this.
Anyway, more testing on different specs is a good idea.
I'm running Mavericks for OS.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
slepy8
ok, honestly - great work on final release!
It's very stable! I have almost no crashes during work!
The possibility of integrating plugin into standard C4D interface is perfect.
Really really great stuff - worth it's money.
If you only got rid of this "hanging problem" in render queue I'd send you a good bottle of polish "whatever you drink" straight to your home :)
DOES ANYONE HAVE THIS ISSUE TOO?? :
You set the render queue of some different files. Prepare the save paths for images and set proper cameras.
Than you hit render, and after some images it just hangs! It stops, and shows a "busy mouse coursor". After that you have to go to task manager and kill the C4D process, nothing else works.
Whats strange - it hangs always JUST AFTER FINISHING the render and after this image has been saved. Like it couldn't proceed to rendering next image.
Hangs happen randomly. There is no rule for them.
Anyone??
This "hanging problem" appeared on each plugin version.
And since I'm rendering about 200 images in the queue each day - it's pain in the ass to keep watching if it didn't hang.. :/
slepy8, didn't check your pm? I have sended a test version rc2.
toqua
aoktar - rc2?
Can i try it with my win8.1?
toqua
SVITAdmin
slepy8 wrote:ok, honestly - great work on final release!
Anyone??
Yes. Randomly. I have had two machines running a render for two days straight. One of them crashed twice yesterday (first time after a day and a half of constant rendering. Second Tim after after a few frames). The other is still going with no crash after three days. The one that did crash is going strong now. They also crash about 90% of the time when a render is completed I have noticed, but as long as the render was done, I didn't care.
We rarely yes render queue though because of our workflow. When we did, we have not had any issues other than the random hangup here and there.
hi,
after a frash install of mountain lion against lion, all the issues under osx are gone ;)
about the render queue issue: i always prefer to render via render queue and i have no issue with my two machines ( pc and mac), but other machines in the studio always crash when saving the last frame. maybe is related to some other plugin or some older setting from previous version of c4doctane stored in the new.c4d file or layouts :roll:
I have found a possible point and l though that's fixed for rc2. liveviewer was open when this last frame crashes? try to close and render.
r15 and win8 problem is still there. it's not a plugin problem
SVITAdmin
aoktar wrote:I have found a possible point and l though that's fixed for rc2. liveviewer was open when this last frame crashes? try to close and render.
any chance of trying out RC2?
Oleg
slepy8 wrote: DOES ANYONE HAVE THIS ISSUE TOO??
I have almost the same problem: when the renderer is almost complete, C4D "hangs" and nothing helps except unloading processes. I hear my video card cooler reduces the rotation, which means the end of the render, I think the problem is somewhere in the return data from the engine can be ... I do not pretend to have a complete understanding of the processes, I just want to get high quality images quickly and steadily x)
Win7 x64
GTX 470
