OctaneRender 2 for Poser (Windows/OSX) [OBSOLETE]
Hi Erick
The commercial version allows the saving of the HDR Light Studio project, and the project is also automatically saved and restored in the Poser pz3 scene. Also, doing a production render results in a much larger HDR map - so higher quality render in Octane. But the demo version is still very good, and if you can put up with manual finding and saving the temp files, and then maybe doing some post work on them to lift the equality, it's a good solution.
Andygraph3D
The poser plugin demo x86 don't work, is not possible installed it ..
i have try with octane 64bit with windows 7 and poser 10
Unsure what you mean here.....What OS or you running? Are you installing for Poser Pro or Poser 9/10?
Andygraph3D
OS: Windows 7 (64bit)
Poser version: poser v10 (x86)
Octane version: Octane v2 (64bit)
plugin problem: Octane poser plugin Demo 32bit (x86)
i have another pc and i want just install the demo version ...
I just checked, and it worked OK for me. Same OS and Poser versions as you have. The plugin should install into C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Python\addons\OctaneRender for Poser. What was the filename of the installer you used? What filesize is it? Can you post the octaneplugin.log file pls?
Andygraph3D
when i start poser installed plugin (x86) it ask the path "C:\Program Files (x86)\Smith Micro\Poser Pro 2014" ... and no poser 10
anyway i search poser 10 folder and install there .. C:\Program Files (x86)\Smith Micro\Poser10
OctaneRender for Poser folder is there but poser dont load the plugin ..
no octaneplugin.log file there
note
the octane render v2 is demo too
Hi - if there is no octaneplugin.log file, then I doubt the plugin was installed.
1) What plugins are listed under Poser->Window->Addons
2) Can you pls post a screenshot of your C:\Program Files (x86)\Smith Micro\Poser10\Runtime\Python\addons\OctaneRender for Poser folder.
Video showing how to import ORBX materials into the plugin.
Andygraph3D
the screenshots ..
Thanks Andygraph3D
Everything looks correct.
Return to “Poser”
