OctaneRender 2 for Poser (Windows/OSX) [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser STABLE RELEASE.
Pls read http://poserphysics.blogspot.com.au/201 ... pport.html prior to posting support issues.
Poser Version
Windows: Poser9/PoserPro2012, Poser10/PoserPro2014 and Poser 11/11 Pro, on Windows XP, Vista, 7 and 8.
OSX : PoserPro2012, PoserPro2014 and Poser 11/11 Pro 64bit, on MAC OS X 10.9.4 onwards.
Nvidia Driver Version
Windows : Nvidia drivers 344.x or later. Avoid Nvidia driver 361.x.
OSX : CUDA Driver Version: 6.5 or later
Network Rendering
For Network Rendering, you must use the Octane slave release 2.25 available from the Commercial Product News & Releases subforum.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. 2.23.1.56)
Also have ready a copy of
- octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory), and
- config.xml, which is in C:\Users\[username]\AppData\Roaming\Poser Pro\9 for Poser 9/2012 and C:\Users\[username]\AppData\Roaming\Poser Pro\10 for Poser10/2014.
Still TODO
- Implement subd processing for props (only implemented for figures at the moment) - will require a Poser SR patch
- Specular map image power defaults to 1 at the moment for skin materials with specular maps. Probably should be about 0.2.
If you have questions....
- Check the specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/Poser/?page_id=298
- Read the latest up-to-date on-line manual
- Read the PDF manual (pdf manual is installed into C:\Program Files\Smith Micro\[poser version]\Documentation)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Watch the Instancing Video
- Watch the HDR Light Studio Video
- Check the Facebook Page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Windows
- OctaneRender for Poser 2.25.0.68 (64 bit)
The previous plugin release can be downloaded from:
- OctaneRender for Poser 2.24.2.62 (64 bit)
The last version of the Windows plugin that was built with 32bit support can be downloaded from:
- OctaneRender for Poser 2.24.1.61 (32 bit)
OSX
- OctaneRender for Poser 2.25.0.68 Poser Pro 64bit (Mac OS X)
- OctaneRender for Poser 2.24.2.63 Poser Pro 64bit (Mac OS X)
ch0pper
working fine at this end first of 2 test renders
with version 2.0
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
dsyee
A couple of minor issues I've come across:
1. In the Render Setup window, if you select a mesh and change one of the parameters and then press Enter, cursor focus returns to Poser even though it appears the cursor is still in the Render Setup window. Clicking on the field in the mesh settings still doesn't return focus (focus stays in Poser). If you click a different field (for the same mesh), you can no longer return to the original one by mouse-clicking. Selecting another mesh in the Material List tree and then re-selecting the first mesh seems to fix it. Maybe a picture would come in handy:
This is different from the behavior when using the keyboard to enter material/texture settings (e.g., rotation/scale values) - those seem to work like you'd expect.
2. Applying subdivision (1) to a particular mesh causes some errors, and then Octane gets stuck here:
Then the plugin freezes and I have to force close Poser.
Here's what the "mainWacros" window says:
Traceback (most recent call last):
  File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 594, in EventOpenViewport
  File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5139, in ShowViewportForm
  File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\RenderManager.py", line 336, in StartRender
WindowsError: exception: access violation reading 0x00000000000000BC
Here's the CUDA error log:
Started logging on 10.06.14 11:21:11
OctaneRender version 2.00.0009 beta (2000009)
Subdivider: A non-manifold edge incident to more than 2 faces was found
Subdivider: An edge connecting two vertices was specified more than once. It's likely that an incident face was flipped
Subdivider: Face 902 will be ignored
Subdivider: Face 903 will be ignored
Subdivider: Face 904 will be ignored
Subdivider: The specified subdivmesh contains disconnected surface components.
Apparently there's something wrong with the mesh, but a freeze seems like a severe reaction. :lol:
[Edit] I just remembered that subdivision isn't supported for props (figures only), is that the problem? But still, a freeze seems a bit severe?
My specs are:
Win 7 Professional SP1
nVidia driver version 337.88
Poser Pro 2014 (10.0.3.26510)
Core i7 2600, 8GB RAM
Two GTX 770 4GBs
Thanks!
Core i7-3770 / 16GB RAM / 2x GTX 780 6GB / Windows 7
wimvdb
With regards to subdivision - figure only subdivsion is Posers subdivision. Octane subdivision works for both
The figure/prop needs to be welded for Octane subdivision (and rounded edges).
Did you run the Weld script in the Octane Plugin menu in Poser?
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
dsyee
Ah ok, thanks for the info re: subdividing props.
I hadn't tried welding it, but I just did, and I still get the same errors. The prop renders fine with 0 subdivision, though.
ThetaGraphics
I've been getting a lot of Cuda Error 702's, especially when messing with displacement. Sometimes causes Poser to crash as well, but not always.
Here's the log after one error (I thought I cleared it before):
CUDA error 702 on device 1: The device kernel took too long to execute. This can only occur if timeouts are enabled. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> Failed to deallocate device memory
-> Could not get memory info
-> Failed to deallocate device array
-> Failed to unload module
CUDA error 702 on device 0: The device kernel took too long to execute. This can only occur if timeouts are enabled. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
-> Kernel execution failed (pt)
CUDA device 0: Path tracing failed
FYI, I have two GTX 670's (Though I typically only use one for rendering to keep from lagging the computer).
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
Yes, I noticed this two, and spent many hours trying to fix it - by python conspired against me. I will take another look.
Can you send me the prop pls?
Potentially the displacement amount is too high. Pls refer to the "Displacement" section of the manual at http://render.otoy.com/manuals/Poser/?page_id=298.
dsyee
Hi Paul,
Actually, it seems like it could be a problem with Octane itself, not the plugin. Loading the OBJ into Standalone and increasing the subdivision to 1 makes it crash instantly.
In case you still want to test it, though, here's the OBJ, which should be all you need (hope I'm not violating any copyright laws!).
Thanks!
[link removed]
Thanks - I'll submit it to the Otoy devs for actioning.
The Otoy devs have investigated this issue and found the error to be happening inside the OpenSubiv library (which is external to the Octane library). So it will not be a simple fix, but they are looking into it in more detail.
So for figures which cause this error - use Poser Subdivision instead of Octane subdivision.
Return to “Poser”
