Cinema4D version 2021.1 XB1 (Preview release) 17.06.2021
mohari.mate
Hi guys, when i load aces ocio 1.2 config and switch to ocio in LV, is there any chance to increase the contrast of the image ? LUTS, gamma, etc doesnt work, only exposure and saturation. Is there any way to postprocess the image ? It would be fantastic. Cuz sometimes it looks flat and dull.
Thanks, Lev
rodney71
is there a walkthrough/instructions somewhere on how to set up render passes in this new AOV system? I can't seem to render out any passes from a file I had set up in an earlier octane plugin release. no matter what aov passes i add the final exr has only one layer in it. i'd like to know if anyone can point me to some basic setup instruction or tutorial.
thank you, Rod.
Rod
Asus P6T Deluxe V2
Intel core i7 920 (2.66 GHz quadcore)
12 gig RAM Kingston HyperX
BFG GTX 285 OCX
CPU cooling - Noctua NH-U12P SE2
OCZ Vertex Turbo 120 GB Sata II SSD
Windows 7 Ultimate 64bit
marcus1070
IImk wrote:
marcus1070 wrote:There's some problem happening with RTX:
RTX off:
RTX on:
Try to disbale nested dielectrics in octane kernel settings
Same result.. RTX issue
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
SSmolak
ELSKSA, thank you for link to great, very informative blog !
Kalua
I have this scene which is giving me 2 very different outputs (2020.2.4 R2 and 2021.1 XB2).
Any ideas?
Regards,
2020.2.4 R2 version
2020.2.4 R2 version
2021.1 XB1 R2 version
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
try to enable Multi Light, to check them one by one, maybe it is related to IES lights :roll:
ciao Beppe
dynaraton
Kalua wrote:I have this scene which is giving me 2 very different outputs (2020.2.4 R2 and 2021.1 XB2).
Any ideas?
Regards,
I have the same exact issues. I was able to get it close by adjusting my IES light output +/- 1000x less to get approximately the same results. There is definitely a problem here.
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
Kalua
Any ideas?
Regards,
Sure something is going on. The point is we should have it fixed for future builds.
Or never import ongoing projects to avoid this problem - just make sure this is something expected by the developers or not.
Regards,
