OctaneRender™ 3.0 for LightWave™ - Test build 3.08.0.0
3dworks
BorisGoreta wrote:would it be possible to automate the following procedure of building a material from a library of images.
Here is a snapshot of all images for one material. They all have suffix which corresponds to an input type.
So I can manually build a material to use all these textures. But when I want to build another one with another set of images I have to change them all manually.
How could I inject all images from a folder to a specific material ( surface ) ?
great idea
juanjgon
Check one of the tools included in the new OD_Tools for LightWave 2018 (OD_PBRImporter)
https://vimeo.com/album/4335852/video/247088794
promity
Juanjo, it's possible to make Octane able to render new lw volumetrics and materials?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
BorisGoreta
Thanks, I hope this works.
juanjgon wrote:Check one of the tools included in the new OD_Tools for LightWave 2018 (OD_PBRImporter)
juanjgon
promity wrote:Juanjo, it's possible to make Octane able to render new lw volumetrics and materials?
You can render OpenVBD volumetrics with Octane, like LW2018, but if you are talking about the light volumetrics and so on, nope, Octane has its own volumetrics system. The same happens with the materials ... as you know Octane only can work with its own material nodes.
BorderLine
BorderLine wrote:Hi Juan and thank for release.
I've a problem with this release with network rendering. Color change in windows zone, more darkness !
Just try rectangle with grass color. Render in local and render with network, rectangle zone become darkness !
Thanks in advance
Franck
Hi Juan !
Think you can correct this bug! It's very annoying for animation calculation!
thank you in advance
juanjgon
The network rendering issues seem a problem in the Octane core and/or standalone, that I'm sure that the developers are aware because it has been posted on the main forums. I suppose that it should be fixed in the next build.
promity
juanjo, thank's for light bug fixing - now I can change any parameters of light when the IPR window is running without freezing everything!
Lightwave 3d
MichaelT
Now that Lightwave 2018 is out, any thoughts on when a build for this version is coming?
Since I have 2015 I can use that of course, but others might not be so lucky :)
juanjgon
The Octane plugin build for LightWave 2018 will be released in few days, once the new Octane 3.08 core is released. The 2018 plugin version is ready, with all the code updated to the new 2018 SDK. It has been in development and tested for months, so stay tuned ;)
Return to “Lightwave 3D”
