Version 3.08-test6.1 (TEST VERSION) updated on 8.12.2017
pxlntwrk wrote:Hi,
It react very well on R18 here, and Uber node is very welcome;)
Thanks for keep this plugin on top !
Great to hear. I'll increase material limit of uber for next releases.
Josef wrote:Thanks so much Ahmet , you just blew my mind with the OSL integration and UI, the EDITOR!!! , it just works !
Happy to hear that;)
Note that parameter types and ui still needs some work. And I'll improve it more on next releases.
enjoy it!
VVG
Thanks Ahmet for fast test integration in C4D 3.08 build
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
NC17z
Between the Toon Shader and OSL Node,... This is the best Christmas a geek like me could ever have,... Thank you Thank you Thank you Aoktar!
Has anyone noticed a little bit of a bump in performance with the view port?
I should also point out that the Toon Renders pretty darn fast too! I'm loving it.
Cheiser
Weird issue with displacement.
Using TextureImage for displace this cube.
thanulee
Now with 3.08 with the new LUT options that will be implemented, can u please create a pass for using em in post?
If i want to export with LUTs my image is 8bit and i cant do nothing else in post. Ideally i wouldnt want a linear render, i love octane cause i can use its LUTs for contrast and not cause i see a boring linear result in my viewport. But this clamping afterwards is killing me and leaving me with 2 choices: either lut and 8bit or linear and get different result.
So is there a way when we render 16/32 exr that we can have LUT information as a seperate pass, same as we have glow? This, or an export of high dynamic range with LUT burned in the image is fine as well.
thanks alot
Cheiser wrote:Weird issue with displacement.
Could you please send a c4d or orbx scene?
mesut
hi,
great update. thx.
i believe to have found a reproducable crash:
1. add light(sky, hdri... whatever)
2. add sphere
3. add octane-material to sphere
4. render in live viewer
5. open node editor of said material
6. connect a node (i.e. rgb) to diffuse
7. delete octane-material from material manager
8. freeze/crash of c4d (the one that shows you a "thinking" circle)
EDIT:
i tried this again, but this time with a "checker"-node instead of rgb... which led to "normal" crash with bugreport and such.
here's the zip, containing everything the report produced:
http://www.mesutcapkin.com/temp/complete_report.zip
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
atcovrett
Awesome work Ahmet! Can't wait to give this a try.
I might have missed this, but will this new version patch the R19 render passes output issue?
Thanks!
Aaron
NC17z
mesut wrote:hi,
great update. thx.
2. add sphere
EDIT:
I'm curious,... Did you update Octane Standalone to 3.08?
I'm in C4D R18, not having those issues.
Locked
