Version 3.08-test6.1 (TEST VERSION) updated on 8.12.2017
Locked
Here is new topic for version 3.08-test6 which is based on TEST SDK(3.08-test6).[/b].
For a detailed description of all new features of 3.08, please read the new features thread.
Changes since 3.08-test6
- Fixed uber interface and missing functionality
New features
  • OSL texture/projection/camera nodes
  • Toon shading
  • Specular reflection and refraction models
  • Metal material node
  • Custom LUT support in tone-mapping (NOT YET ready on plugin. Will be added for next build)
  • Additional response curves
  • Improved clay rendering
  • Uber material: Simplified workflow for mix material system with embedded materials. Note that's for preview and feedback. And limited to 3 sub materials at the moment. I'll improve and shape it up by feedbacks. Thanks for understanding!
Important warning about R19 build:
Saving of passes functionality in Octane RenderSettings is broken due a bug on R19 SDK. So you can try to use C4D's save for multi-pass image until we get fix/update from MAXON.
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... .1-win.zip
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OctaneRender™ Standalone 3.08-test6
viewtopic.php?f=33&t=64362
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.024). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(at least 37x.x(Cuda 8.0) - rollback to versions if you have much trouble with latest drivers
MANUALS:
Offline HTML: https://render.otoy.com/plugindownloads ... manual.zip (extract to c4doctane directory)
Online manual: https://docs.otoy.com/Cinema4DH/C4DPluginManual.htm
Partial help for Instance Color and Instance Range nodes:
Instance Color: https://drive.google.com/open?id=1uMyw4 ... mvoaHyYBVb
Instance Range: https://drive.google.com/open?id=1FF1ad ... eY8XjD10w1
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Uber material sample
lehmannudo
Hello aoktar,
thank you very much for the update but unfortunately without alembic-particle identification :(
lehmannudo wrote:Hello aoktar,
Sorry but i had to complete other things.
thanulee
No subscription build yet? ty
thanulee wrote:No subscription build yet? ty
Subscription builds will be available only with stable releases anymore. Thanks!
Silverwing
Hi Ahmet,
thanks a lot for your hard work on the newest built. I really appreciate your continuous effort to bring the best of octane to C4D. Keep up the good work.
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
eyeonestudio
WoW Thanks... Happy Weekend. :D
thanulee
Btw, i think i read somewhere that displacement is fixed on this build? cheers
Voltago
Thanks a lot, Ahmet! The version behaves nicely so far in R18, I'm already in love with the Uber shader :)
Studio21
Nice ahmet, thx for all the hard work. working well so far :)
Best,
Guy
Locked
