OctaneRender™ Standalone 3.04
doca
bepeg4d wrote:Hi doca,
please, try with "Tonemap the render passes" option active when saving info passes.
Hi beppe, abstrax,
Render passes works fine except "Lighting passes". Here is an example , and I have to mention that light ID setup is properly done and it works in Octane 3.03.04, (screen grabs of the same screen portion):
BEAUTY:
Ambient color looks ok:
But, Light ID1, ID2, ID3.... Are not working:
Object Color ID is ok, too:
abstrax
Hi beppe, abstrax,
BEAUTY:
I can't reproduce the issue. For example in this little test scene, it works correctly as far as I can see:
light_pass_test.orbx
-> If you could send me a scene that lets us reproduce the issue we are happy to fix it as soon as possible.
nuno1980
@abstrax:
NOTICE: Please should reply me - my message :?
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
doca
abstrax wrote: -> If you could send me a scene that lets us reproduce the issue we are happy to fix it as soon as possible.
Hey absrax, your scene renders correctly. No luck with my scene.
I've attached simplified scene that renders lightID passes wrong way. Can't figure what is the problem. In 3.03.04 everything works fine.
Best,
Doca
abstrax
Best,
Doca
Thanks for your scene. I found and fixed the issue. Since there were a couple of other annoying issues, we plan to get a new build as soon as possible. Probably at the end of the week.
doca
Best,
Doca
Great to hear that!!!
And, if i can suggest for that release:
gah5118 wrote:awesome!
love the batch render node. One improvement that would be great; add the file path selection to the main node rather than asking when running the render. This way, the node can be saved to your localdb and reused with the same settings every time.
abstrax
doca wrote: Great to hear that!!!
I don't fully understand. Why would you always want to render into the same directory? Or do you mean something else?
calus
abstrax wrote:
gah5118 wrote: love the batch render node. One improvement that would be great; add the file path selection to the main node rather than asking when running the render. This way, the node can be saved to your localdb and reused with the same settings every time.
Gah's argument about saving batch render job to localdb is confusing and has nothing to do with the Output Folder problem.
The point is : why would you want to have to set the Output Folder everytime you run the batch render job ?
Output Folder shouldn't be an interactive step, but should be one of the the imput of the batch render job.
Also considere to change the default filename template from %n_%f_%p.%e to %n_%p_%f.%e,
because most of the applications need frame number to be at the end of the filename to recognize an image sequence.
Pascal ANDRE
Elvissuperstar007
slice cap
add to in the road map
doca
abstrax wrote: I don't fully understand. Why would you always want to render into the same directory? Or do you mean something else?
Ok, it is not well explained.
The point is to have already predefined frame range and output path for each Render target (different paths, different frameranges). Lets say, I do have project with multiple cameras, or multiple shots, and I want to render them all over night. Now, I can set output and frame range only for one, right?
And I have to change output path and frame range every time I hit batch render if I do have multiple Render targets. Right again?
There is my suggestion in the attachment. And suggestion is to have option to define frame range and output path for each Render target. That way I can have multiple Render targets rendered overnight without having to wake up and setup new path and frame range for each sequence/Render target.
I hope, that I explained well. :-)
Best,
Doca
