OctaneServer 9.11 crashes every 5-10 minutes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
@JimStar
OSX users need a simple answer. When do we get fixed OctaneServer? In a case you can't find a working osx machine you can rent one in a cloud:
http://www.macincloud.com/
System – Windows 11
I'm sorry guys, but it's not me who decides when to buy the expensive assets. I've made a request and got a promise to supply it, that's it.
J.C wrote:In a case you can't find a working osx machine you can rent one in a cloud
No I can't. The NDA stuff (which the plugin's source code and Octane SDK is) can't be uploaded onto any non-Otoy external resource.
J.C
Thanks for the reply but this is funny :D
You somehow produce a software but don't have a hardware to release it. Have you smashed your OSX machines?
System – Windows 11
afecelis
JimStar wrote:If you still have some issues with LiveDB - just re-download the 9.12 version and reinstall it. For Windows it is enough to just re-download the OctaneServer installer.
Thanks a lot! I hadn't seen this post. I was about to go back to v9.11.
Things working ok now.
regards,
Alvaro
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
J.C wrote:Have you smashed your OSX machines?
No. It was just coincidence that the build environment used previously by Octane standalone had been OK for building Blender too (which needs a lot of special Blender Foundation's requirements and dependencies). So, I just used the machine that is used for standalone. But now the Octane core team has changed the build environment so significantly, that Blender can't be built on this machine anymore. This is totally broken for Blender now. And if I will "fix" it - I will totally break the build environment for standalone (and all its satellites - bench, SDK, etc).
So, this is why the separate machine is now needed for Blender - to have the special build-environment especially made for Blender, which has the guarantee that nobody will make it broken at any point of time making a full re-set of it for some other project...
J.C
JimStar. Thank you for an answer. I hope you will be supllied with a new Mac machine soon. You can always use a PC machiche with a virtual machine software where you can install OSX with
System – Windows 11
J.C wrote:You can always use a PC machiche with a virtual machine software where you can install OSX with
No, it is not possible to use it for this purpose.
Locked
Return to “Bug Reports”
