OctaneServer 9.11 crashes every 5-10 minutes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
aLeXXtoR
...independently on my activity (even if my PC is in IDLE and Blender isn't runing).
Sometimes there is a system window appears that applicaton has crashed, and other time it just silently stops.
A. OS Windows 7 with lastest updates at the current date
B. GTX 680 4Gb + GTX 770 4Gb
C. 24 Gb RAM
D. Nvidia GeForce Game Reay Driver 368.39
E. OctaneRender Standalone 3.02
F. OctaneRender plugin for Blender v2.25, OctaneServer v9.11
G. Blender 2.76b Octane Render edition
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
grimm
On Linux it will not even start now. :( It must have something to do with the new licensing as it was working fine before. Here is the error I'm getting:
jason@gemong ~/graphics $ OctaneServer
OctaneServer v. 9.11
Octane: Starting Octane engine...
Octane: ...started
Octane: Activating license...
Octane: found stored license info...
Octane: ...activated
Octane: LiveDB cache refresh started...
OctaneServer: malloc.c:2372: sysmalloc: Assertion `(old_top == (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long) (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk, fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) - 1))) && ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)' failed.
Aborted
Thank you for report.
I don't think it's related to a new licensing... But it's definitely strange that it started to happen only now... Looks like something related to LiveDB data. I will check this.
aLeXXtoR
JimStar wrote:Thank you for report.
Thank you! I is very uncomfortable to work with it :(
WebSite
Showreel
grimm
Awesome, thanks Jimstar! :D
matic
Same problem for me Octane Serveur 9.11 crash every time I start a render or during a live tweaking shader.
This is very non productive for me, I always restart octane server and lost the pleasure of working with it.
I use Blender last release 9.11 (2.76) and the last Octane server too.
GTX 780 x2 - pilote version 359.00
http://www.mathieufrossard.com
I found the problem, the new LiveDB data on the network suddenly triggered this "brand new" issue in this stable version.
I've already fixed it, and going to release the Windows and Linux versions with this fix tomorrow.
The only negative here - the OSX version can't be built currently for technical reasons. I will build and release it later, as soon as I get and set up an OSX build-machine for it... Apologies for inconvenience...
aLeXXtoR
Thank you, JimStar! Great news! :)
WebSite
Showreel
matic
Thanks for the answer. I will check if all work good.
grimm
Thanks JimStar, it's working again. :D
Locked
Return to “Bug Reports”
