OctaneRender™ Standalone 2.24.1
Elvissuperstar007
roeland wrote:My guess is VRay does something similar as this node graph:
dome + ground plane.orbx
You may go into that graph and replace the images in the two image texture nodes.
Roeland
hdr top, bottom a background
I'll check
https://cg-source.com/products_hdri_timelapse.php there's even a sequence
Elvissuperstar007
change gamma of 1.0 hdr , this is the best of the existing HDR
https://cloud.mail.ru/public/DLvV/oytrohgby HDR
Elvissuperstar007
Roeland
You are the best!!!
it is necessary to insert into octane, we need to integrate
still need border Blur option
LuvMultimedia
I can't seem to batch render image sin a sequence, e.g., render 1, render, 2, render 3 -- the images save on top of one another and do not render....
WIN 10 64 | Geforce 970| 16 GB
kavorka
you need the %n in the filename for it to name the image based on the render target name and the %f for it to name it with the frame number.
Those % characters get replaced with what they are associated with. Hover over the template area and it will tell you what they are.
LuvMultimedia
kavorka wrote:you need the %n in the filename for it to name the image based on the render target name and the %f for it to name it with the frame number.
Ohhhhhhh, Thank you Thank you so much!
LuvMultimedia
Would you mind giving me a screenshot (if you have time) as a reference so I know I am doing this right?
LuvMultimedia
so would it look like this " %n %f mirrors"
kavorka
make a new octane file, the default settings of the batch script will be there, copy and paste that. Just use that. you can add the "mirrors" where you would like, as long as it is before the .%e (that is the file type and needs to be last).
LuvMultimedia
kavorka wrote:make a new octane file, the default settings of the batch script will be there, copy and paste that. Just use that. you can add the "mirrors" where you would like, as long as it is before the .%e (that is the file type and needs to be last).
Thank you -- it's workin' now -- you so rawk!
