OctaneRender™ Standalone 2.24.1
mojave
Hi all,
This is a maintenance update for 2.24 fixing bugs reported since the lastest version.
Changes since version 2.24.
  • Fixed issue that caused a crash while saving data into the local DB.
  • Batch render script saves the beauty pass as RGBA in multilayer EXR files.
UPDATE: Added demo versions
Downloads:
Windows
- 64-bit commercial version (installer)
- 64-bit commercial version (ZIP archive)
- 64-bit OctaneVR (installer)
- 64-bit OctaneVR (ZIP archive)
- 64-bit demo version (installer)
- 64-bit demo version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image)
- 64-bit OctaneVR (DMG image)
- 64-bit demo version (DMG image)
Linux
Happy rendering,
Your OTOY NZ Team
Draydin_r
Awesome!
Also, you might want to fix the typo "Batch render script saves the beauty pass ass RGBA in multilayer EXR files." ;)
Intel Core i7 CPU 6850K @ 3.60GHz 128.0 GB Ram / Win 10 64 bit / 1x GeForce RTX 3080
FrankPooleFloating
Hey, could you please pass the ass? :lol:
Fixed. Thanks.
oguzbir
There is a lack of Random Bitmap feature.
The problem originates from 3dSmax scatter and instancing plugin Forest Pro for max, which is a major plugin professionals use.
Also there are other plugins (like RailClone Pro) where I as a visualisation artist or other plugins that Architectural users use day to day, to create,
say eg. a floor that has individual objects (floorboards) that they need to be assigned with bunch of different textures, and/or a single texture with color correction variations.
Eg.2:
Think of a land with grass objects and flowers have textures. It's crucial to assign each object a different texture or variations of one.
To do that I guess you'll have to implement something to drive random bitmap textures.
Currently Forest pro, Railclone like plugins support these. But octane doesnt.
Since Max' system and userbase relies on the additional plugins. This is a major problem for most scenarios like above.
Forest Pack pro has it's own Texture that enables you to add some textures and let you change color tints based on assigned textures.
The Forest color texture is already implemented in Standard, Mental Ray, and V-Ray and Corona renderers.
This problem is also similar to MultiTexture Map plugin. Where most professional Archviz users use those plugins every day.
I would like to ask you to either implement above plugins/features specifically for max only.
Or
Create a new texture map for octane to let us randomly assign bunch of texture to many obj instances.
As this is related to the Core...
And AFAIK our max developer Jimstar does not have a copy of Forest Pack Pro and Railclone or MultiTexture Map.
Karba used to have some the above plugins.
Your response is highly important for people like me.
The Random Color Texture node doest some part of the job but there has to be a way for us to create random Bitmap textures
My Portfolio
Elvissuperstar007
I can not work properly without the support forest pack , Reil clone, MultiTexture Map https://cg-source.com/multitexture.php
I hope it will add 2.0, wait another year - two of 3.0 it will be unbearable
coilbook
[quote="oguzbir"]Hi,
Eg.2:
We asked Otoy many times about random texture feature and not just random color. Because if I want my forest to have different shades of leaves I cannot use texture and have to use gradient color with random color input. I wish they can add like a 10 slot shader like mix material with a random texture input
immortalartscom
hey, thx for release. here network render worked always perfectly till 2.24.1... is it possible that there were some changes on your side? i use c4d plugin but ahmet ensured that this is a standalone problem.
the clients take very long to show up on master. so long that the first 10 times i tested it, i did not wait till they were there... :)
c4d also crashes because of that...
any ideas?
thx
immortal-arts | filmproduction | soundstudio
http://www.immortal-arts.com
immortalartscom
why is it so hard to get a answer here?!?!?!?!?!?!?!
Otoy probably need more info on this - for instance, what is the host and slave operating systems?
