Quixel SUITE 2.0 Revealed
Goldorak
prehabitat wrote:
gordonrobb wrote:A very quick play. Not trying much. A simple bit of geometry, exported with a UV. Quixel baked all the maps it needed, and I spent 10 minutes doing this to it. Will need to find the time to do a good object :)
Pretty awesome,
OTOY Devs; is this kind of live map creation possible within octane 3 using the UX changes and/or Lua?
I think with full script node API + OSL textures, procedural nodes like this should be easy for us and 3rd parties to add to Octane 3
gordonrobb
Pretty awesome,
I'm not sure why. Quixel Suite is fundamentally a texture painting tool. It's for creating the textures that will be used by the renderer. They are working on an Octane Exporter as well.
prehabitat
gordonrobb wrote:
Pretty awesome,
I was thinking * that painting using a native octane procedural in the scene (ie with all the context & coloured second-hand light rays) using the algorithm and environment from the final scene rather than an alt-tab, single-model refine & sync would be preferred.
*note: not really my field, but I f I could get all my (applicable) materials procedural based and make in-scene tweaks using my Wacom that'd be pretty cool. Would rather the functionality within octane then elsewhere. Already enough stepping stones in my workflows
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
gordonrobb
Ah ok. might be worth mentioning in a feature request thread. No guarantee the developers will look at a thread about an extremal texture painting app.
ristoraven
Just got into new round of beta testing. If anyone is interested go to polycount forum @ www.quixel.se and ask to join.
Been fiddling around with this few hours and this is a.w.e.s.o.m.e.
Rikk The Gaijin
I got in as well, even if every single one of my post I was basically insulting them, LOL. :lol:
gordonrobb
That's great. Can't wait to see what you guys can do with it. I'm still hacking around with trying to turn on ald high poly mesh into a lo poly, but the bits I've messed with the suite, are a blast. Here's my latest update (material is merely a test of the Low poly and UV)
ristoraven
Since there is not yet Octane presets available, what do you use for Octane?
I have thus far tested only Maxwell maps and got a pretty decent results..
fatrobotsneedlove
ristoraven wrote:Since there is not yet Octane presets available, what do you use for Octane?
I still don't know how they're going to implement an Octane preset until an IOR map input is introduced in Octane V3 through OSL. Until then you have to export a metalness map and use it to drive a Mix Material.
I also find that the roughness map needs a little tweaking coming out of any of the other presets.
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
fatrobotsneedlove
Rikk The Gaijin wrote:I got in as well, even if every single one of my post I was basically insulting them, LOL. :lol:
:lol: :lol: :lol:
Return to “Off Topic Forum”
