Hi I canconfirm that script doesen`t work in max 2014 and Octane 2.23.2-2.8 because you saved file Scene_HdriV4.mat in max 2016.oguzbir wrote:yeah the mat file is the problem.mark0spasic wrote:I still get the same message. Maybe your file OctaneShortcuts\Scene_HdriV4.mat is saved in max 2016? I`m using max 2014 Octane 2.23.2-2.8 and Octane shortcuts v4.3 , I previously had installed v4.2 and everything was ok.
I corrected it earlier.
maybe you changed it in max2016 ı dunno.
if you ever change the mat file do the changes in 2014.
I'll be back from vacation in 2 days we'll sort it out.
if problem remains drop me a PM
Octane Shortcuts v4.3 released!
- mark0spasic
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
Hi, I've already updated the ver.4.3 download link.mark0spasic wrote: Hi I canconfirm that script doesen`t work in max 2014 and Octane 2.23.2-2.8 because you saved file Scene_HdriV4.mat in max 2016.
You can go and download the newer file. (with the same name Octane_ShortCuts_v43.zip)
or just download the MAT file below and put this in the C:\OctaneShortcuts folder.
My Portfolio
cool stuff
my script still has something like 0.14f version, and your's is 4.3
- have to be more optimistic, but now I can finish it only if I used the new kernel - still heavily relying on the old kernel and max 2015 - the version 3 is probably going to get me
- I'm thinking on how to convert the old material version to the new ones, since I've saved a lot of my custom materials, and have loads of projects on old kernel, it's gonna be difficult readjusting all over..
3dmax, zbrush, UE
//Behance profile //BOONAR
- mark0spasic
Thank you Oguzbir now everything works as it should!
hi oguzbir
i have installed your script at work - no problem.
no i try to install it here at home, but if i just drag it to a viewport, it dosen't show up in main ui.
if i install via utlilities > maxscript > run script i get the attached error.
i'm running windows 10 at home, and i guess it has something to do with that :-/
jorgensen
EDIT
i ran 3ds max as asministrator - now i works.
jorgensen
EDIT
- Attachments
- Capture.PNG (6.76 KiB) Viewed 6638 times
when i try to start octane_shortcuts, i get this error:
unknown property "texture_tex" in unindifined.
does anyone know how to fix this?
- Attachments
- error.JPG (16.29 KiB) Viewed 5964 times
Drag the scrip to the viewport and I look in the Customize Menu the Oguz and nothing. This version not work,the version 3.2 work.
Cosmos II, Asrock 79 extreme 11, Intel i7-3930K 4.40 GHz, 32gb Ram Quad 2.400 OC., 2 Drives Intel SSd 520 240gb Raid 0, 1 Gtx 580 3 gb + 3 Gtx 590 4Gb.
This script is intented to work with after max plugin 2.2 with added maxscript capabilities. The older versions work with prior with the 1.9 plugin versions.snake12 wrote:Drag the scrip to the viewport and I look in the Customize Menu the Oguz and nothing. This version not work,the version 3.2 work.
Jorgensen :
That is simply because you run the the script with an older scene made with 1.9 or prior versions.Jorgensen wrote:when i try to start octane_shortcuts, i get this error:
The environment map in the old files tend to work differently now, due to the changes in the plugin by jimstar.
So what you can do is to copy current environment map to another material editor balls. Make a copy of that
and clear the current Environment Map. By right clicking and press Clear.
Then run the script.
Lastly sorry guys I some how wasnt subscribed to the post. And I just saw your questions.
My Portfolio
I don't have max version under 2014 and can't test it .manos wrote:Hello, is there a ver for Max2012 ?
Thanks.
So, sadly no.
My Portfolio
