OctaneRender™ Standalone 2.13
smicha
Looking at new benchmarks 980 seems to be almost as fast as 780. Great job guys!
Bulwerk
I just ran The trench benchmark and the increase is awesome!
4x980's on liquid
Alpha shadow off, Coherent mode on, Pathterm 0.3
2.12.1
DL: 78Ms
PT: 21Ms
2.13
DL: 119 Ms
PT: 31.5 Ms
So ~%50 increase in performance!
Thanks Octane team!
abstrax
Rikk The Gaijin wrote:I'm trying the new animation script that is supposed to save all the render passes, however it doesn't work... :(
these are the passes as I see them in Octane:
Full frame
Reflections
Refractions
And this is what the script is saving out... :?
The files called "refractions" are actually the full frame ones, and then I have those weird files with letters, numbers and symbols... :?
We uploaded a minor update of the Standalone version that fixes this problem.
abstrax
bepeg4d wrote:Hi Marcus,
great work as always, but something is missing in the osx version, seems like is not possible to create the boolean node, see the attached images:
We uploaded a new version that should fix this problem.
Rikk The Gaijin
Thank you guys! The script now works, but the multi-layer EXR is still empty. For now I can use the PNG, so I'm good, but you might want to check it out...
stratified
Rikk The Gaijin wrote:Thank you guys! The script now works, but the multi-layer EXR is still empty. For now I can use the PNG, so I'm good, but you might want to check it out...
Is there something in the Octane log? Can you get me one of those files?
cheers,
Thomas
Rikk The Gaijin
stratified wrote: Is there something in the Octane log? Can you get me one of those files?
Here, check the attachment. Btw, to open it, I simply drag it in Photoshop.. Is that correct, or do I need to do something special?
frame_0001_all.zip
(23.93 MiB) Downloaded 390 times
stratified
Hey Rikk,
There's no problem with this file, it has 3 layers (Beauty, Reflection & Refraction).
I'm a Linux guy so I don't know about Photoshop (But I think you need a plugin for multi-layer EXR). I use djv viewer which works excellent and is free. You can get it here.
cheers,
Thomas
Rikk The Gaijin
I see, thank you for the info! 8-)
abstrax wrote:We uploaded a new version that should fix this problem.
Thanks marcus, perfect ;)
