OctaneRender™ Standalone 2.13
Looking at new benchmarks 980 seems to be almost as fast as 780. Great job guys!
We uploaded a minor update of the Standalone version that fixes this problem.Rikk The Gaijin wrote:I'm trying the new animation script that is supposed to save all the render passes, however it doesn't work...![]()
these are the passes as I see them in Octane:
Full frame Reflections Refractions
And this is what the script is saving out...![]()
The files called "refractions" are actually the full frame ones, and then I have those weird files with letters, numbers and symbols...![]()
We uploaded a new version that should fix this problem.bepeg4d wrote:Hi Marcus,
great work as always, but something is missing in the osx version, seems like is not possible to create the boolean node, see the attached images:
- Rikk The Gaijin
Thank you guys! The script now works, but the multi-layer EXR is still empty. For now I can use the PNG, so I'm good, but you might want to check it out...
- stratified
Is there something in the Octane log? Can you get me one of those files?Rikk The Gaijin wrote:Thank you guys! The script now works, but the multi-layer EXR is still empty. For now I can use the PNG, so I'm good, but you might want to check it out...
cheers,
Thomas
- Rikk The Gaijin
Here, check the attachment. Btw, to open it, I simply drag it in Photoshop.. Is that correct, or do I need to do something special?stratified wrote: Is there something in the Octane log? Can you get me one of those files?
- frame_0001_all.zip
- (23.93 MiB) Downloaded 429 times
- stratified
Hey Rikk,
There's no problem with this file, it has 3 layers (Beauty, Reflection & Refraction).
I'm a Linux guy so I don't know about Photoshop (But I think you need a plugin for multi-layer EXR). I use djv viewer which works excellent and is free. You can get it here.
cheers,
Thomas
cheers,
Thomas
- Rikk The Gaijin
I see, thank you for the info!
Thanks marcus, perfectabstrax wrote:We uploaded a new version that should fix this problem.
