Google Cardboard VR and OctaneRender™ 2.0
Jorgensen
ok - i just found out there is a texture limit by apple / iphone at 2048x2028 - so a side by side image can be max 2048x1024.
if you do side-by-side stereo pano renders, the aspect ratio should be 4:1 like 2048x512. In this case is better to do over-and-under stereo pano render with an aspect ratio of 1:1 so you can use all the 2048x2048 pixels ;)
Jorgensen
hi beppe
thanks for the info - 2048 x 2048 sure is better :-)
i wonder what effect "St. dist. falloff" is - should it be a 1,0?
thanks
jorgensen
hi,
the Eye Distance Falloff is used to control the distance effect at the poles, in theory, you should reduced it below 1 if flat surfaces seem to be curved at the poles.
