OctaneRender™ Standalone 1.25
p3taoctane
Maya Shader Writing??
When I write an ABC file out form Maya and us teh little wrench to turn on shader inputs it works great.
But my camera animation is no longer been written out. In the bottom of the ABC scene node is an persp "circle" it doe snot plug into a thin lens camera ... can you explain the purpose of this.
The mesh node can plug into a placement or geometry node so I get it.
Am I missing something obvious?
roeland
What do you mean with a persp circle? The loaded scene should have a geometry output, and if there is camera data in the file, it should also have one or more camera outputs. You are likely seeing a camera output named "persp". These connect to the camera input of a render target node.
Roeland
p3taoctane
Duh. yep right you are!!
I was trying to plug the persp node into a thin lens cam :oops:
Thanks Roeland... I should have got that one myself!
Loving the new stuff by the way. I did a export zbrush blendshapes into maya and abc out to octane and morphed nicely!!!!
Keep it up
Peter
p3taoctane
I Love you guys!
There I said it : > ))
1.25 is without a doubt bitch'n, bad-ass, MF'n, rock'n, shweetly groovy!!!
great envy for maya users:(
from c4d the alembic files are always mono-material :(
p3taoctane
BebeTeh maya ones are too unless you click on the spanner and tell it to ignore same names.
Hope that fixes it for ya
Peter
Area D
hi, background image don't work for me.. :roll:
Intel Core i7 950\Zotac ION 512 mb, 1 Gainward 780 ti 3 gb\ 12 gb\ W7
steveps3
Unusual bug, the -n command line flag doesn't work. I tested it in v1.20 and it worked there but not in the latest version.
I am trying to write a blender exporter script but the lack of a -n option means that I an unable to generate new .OCS files.
(OS) Windows 7(64)
ok, finally i have figured out, the issue was not the c4d alembic exporter, but my brain :)
deactivate the option "Merge materials with the same name" in the octane's alembic import preferences, works also with c4d-alembic files, sorry for the mistake :(
anyway, seems that the option works with the suffix "Material" in the objects names, so the result is always only one pin for all the materials.
Could it be possible to add a second option that looks to the prefix of the object name? otherwise the node-graph seems again a spaghetti-madness even with simple scenes :roll:
I need to make some more tests because the "Detect instances" option doesn't work as i expected :roll:
alembic-test-04.zip
c4d, obj, alembic, ocs files
(706.6 KiB) Downloaded 183 times
niuq.cam
:D i try this today. Thank you Beppe. You are a master. ;)
Edit : Would be great. On my scene, actually this detail multiply by five the number of the slots to fill. A huuuuge amount.
