OctaneRender® for 3ds max® v1.11a[Test]
JuM
Thanks Karba!!! realy thank you so much. Finally i can use just octane from start to end!.
Karba
Vanya wrote: I do render without problems.
but when I turn to Dirt texture, it happens... and ''max crash''
Seems dirt texture doesn't work properly with material preview. We will fix it.
wisemanxxx
and HDRi importance sampling bug fixed I guess.Thank you
Vanya
Thanks.
can you add some new maps in the new release?
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
be_fast
Thank you so much for this release! I love it
asus p8b ws [email protected] RAM-16gb and 3xGTX580 3gb I love octane and you guyz doing amazing job for us, THANK YOU
wisemanxxx
I guess there is another bug with HDRi importance sampling. When I switch off alpha shadows there is a lot of fireflies and noise like without importance sampling.But I switch on again they're all gone.
mbetke
This is what I reported with last version too. Seems it is not fixed.
PURE3D Visualisierungen
Karba
wisemanxxx wrote:I guess there is another bug with HDRi importance sampling. When I switch off alpha shadows there is a lot of fireflies and noise like without importance sampling.But I switch on again they're all gone.
Do you have this issue in 1.11a version?
adriano.ol
Having problems trying to make a dome master image (for fulldomes) with new Spherical Camera: I can't reproduce a circular fisheye lens, like vray dome camera does, for Octane tends to "square" the render.
Fov: 180
Fov y: 180
Res: 800x800
oguzbir
Hi Karba,
Thank you for the update.
I'm getting random crashes with my different scenes..
Usually when refreshing the octane viewport. or moving vertex of a moveable proxy object, while it is rendering a side.
With or with out dirt texture in the scene.
I had no crashes before.
I cannot reproduce the error this time something has to do with the new things in octane plugin.
Now it's crashing like the old 3dsmax 6 or 2.5 used to crash :)
FYI
My Portfolio
Return to “Autodesk 3Ds Max”
