OctaneRender 3 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
rajib
face_off wrote:Following is a pre-release of the next version of the plugin. There is an issue with the Octane 3.05.2 Daylight Environment node, so I will wait for the next Octane release before fully releasing the next DAZStudio plugin.
3.5.2.30
Thanks Paul. Have been a bit too busy with office work. But will download now and give it a try tomorrow. Will get back if I find anything new.
Regards,
Rajib
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
AlfaseeD
Hi Paul
I don't want to push you, but do you think that it will be possible to get the automatic material conversion as I showed you in my previous message ?
For me that has became fundamental to keep using octane.
Thanks!
Yes, but are you able to answer my question from a couple of post up pls?
have looked into this further - but it is not clear from your screenshot exactly which Iray Uber shader image maps you what connected to which Octane Glossy material pins. Can you pls provide an exact mapping of what you want pls and I will code it.
AlfaseeD
face_off wrote:Yes, but are you able to answer my question from a couple of post up pls?Paul
This is pretty weird. I check this forum daily I didn't see your reply ... Well, sorry :D
Ok, I can provide to you anything you need, screenshoot, files, etc, but I think I can easily summarize with few words.
Anyway, if I'm not clear, I will explain my self with some screenshot.
Basically most of shader featured in Daz products have this pattern :
Metallicity map plugged into the Metallicity node.
Diffuse map plugged into the base color node.
Roughness map plugged into the glossy roughness node.
Bump, normal, displacement as usual.
Me, Stonemason, Polish, Petipet, etc use this very same shader.
Now, the closest result I achieved in Octane is this Glossy material :
-Diffuse map plugged into the diffuse/rgb image node.
-Diffuse map plugged into the specular/rgb image node with gamma 1.6.
-Roughness map plugged into the roughness/greyscale image node.
-Index of refraction set to 1.
All other maps normal, bump, displacement as usual.
We don't need the merallicity map right now!
I hope I made myself clear :)
Ps If this conversion works fine, there is also the Emissive material to take care, but I think this will not cause too much trouble and I case I will provide the exact setup!
Can you send me one of these shaders so I have something relevant to test the new code with pls?
Notiusweb
Hello and Happy 2017!
Here is a weird one, I looked on Daz forums about mirroring/flipping an OBJ, and the forum poster suggested flipping Z-Scale in Parameters from 100% to -100%.
When I do this, the OBJ flips in the DAZ viewport, and renders natively in DAZ as flipped, but in Octane plug, even if you refresh, move, close out and re-open, etc, it is not flipped.
What the flip is going on.
Thanks!
Z Scale for OBJ @ 100 (normal)
Z Scale for OBJ @ -100 (flipped).  Not matching in OCDS
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Fanthomas
3.5.2.30
- Compiled with Octane 3.05.2
- Added support for Instances Groups - so UltraScatter and Voxelizer scenes should now work. There are some limitations to this due to some oddities in DAZStudio. For example, if you instance an object of figure which has a child object/figure, the instance source must have it's scale at 100% and rotation at 0.
- Fixed issue where loading a scene whilst the current scene is rendering would cause the Octane Viewport to step rendering in some situations - requiring a plugin restart
- Added "LiveDb material download failed" message when a LiveDb material cannot be downloaded
https://render.otoy.com/customerdownloa ... _Win64.exe
I am also currently looking at how IRay Uber materials can be better converted to Octane materials (see separate announcement thread for details).
Hi Paul
"LiveDb material" now works without problems!
Thank you Thomas
Motherboard Model:MSI X99A SLI PLUS(MS-7885)
Processor Name:Intel Core i7-5820K
Total Memory Size:32 GBytes
Video Chipset:2X NVIDIA GeForce GTX 970 4GB
GeForce Game Ready Driver Version: 376.33
I checked the plugin code, and for a reason that is not obvious, any negative scales were being multipled by -1 (ie. being made positive again) - causing the flip to not work. I have removed this code in the version below - can you pls test it? The de-negative scaling code may have been there for a reason, so removing this code may have adverse effects in other parts of the plugin - so pls let me know how you go with it.
3.5.3.30 (pre-release)
- Compiled with Octane 3.05.3
- Negative DAZStudio prop/figure scales should now set to negative Octane Placement scales (so flipped props/figures in DAZStudio should now render correctly)
I have updated the installer at the top of this thread with:
3.5.3.30
- Fixed issue where Shadow Visibility on/off changes were not being applied to the Octane scene until the next reload
- Added better support for Iray Uber Materials. For users experiencing further Iray Uber material conversion issues - pls see viewtopic.php?f=44&t=58442
AlfaseeD
nvm !
Return to “DAZ Studio”
