OctaneRender for Rhino 3.03.2 [OBSOLETE]
Ryan - I will see if their proposed solution can be implemented (by splitting meshes). I suspect scene load time will be slower, however I might have an option in the config "Check Clipping Planes" which is off by default to keep things fast. I probably can't look at it until early next week.
I have refreshed the installers at the top of this thread with:
2.21.1.33
- Fixed issue where the LiveDb could not be opened from the Material tab
Also - I have had reports from users that in Rhino5 SR11 pressing ESC when focused in the Material tab causes the material widgets
to disappear, and Rhino needs to be restarted to get them back. This is happening on Rhino materials as well as other renderer materials. So I recommend not updating to SR11 until more is known about this issue.
Bendbox
face_off wrote:Ryan - I will see if their proposed solution can be implemented (by splitting meshes). I suspect scene load time will be slower, however I might have an option in the config "Check Clipping Planes" which is off by default to keep things fast. I probably can't look at it until early next week.
Thank you Paul, and it's no rush. Your idea about a config option sounds great to keep the scene load time fast.
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
newske
I'd look forward to this - seems very useful despite if it is slow!
Regards,
Cam
Octane for Rhino | Windows 8.1 x64 | i7-3820 OC | GTX970 4GB OC & GTX 560 Ti 1GB OC | 32GB DDR3
prehabitat
to disappear, and Rhino needs to be restarted ....
So just to clarify; SR11 fixes the materials & octane tabs teaming up to eat the widgets(see known issues on both rhino threads), however introduces a different issue? #scaredofupdatesnow
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
SR11 introduced a new issue - so I recommend staying with SR10. McNeel have said the SR11 issue with be fixed in SR12.
2.21.1.34
- Fixed formatting of Out of Core Textures in the Cuda Devices screen
- Fixed potential error when saving the configuration/settings
- Fixed exception when trying to load an ORBX proxy
Release notes are now also repeated in the first post in this thread.
Daniel79
now sr11 is ok or not ...i can update?
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
The critical issue has been fixed by McNeel in SR11, however there are still some minor UI issues. Whilst should impact you, keep a copy of the SR10 installer handing in the unlikely case you need to roll back.
2.22.0.34
- Compiled with Octane 2.22. Refer to Octane 2.22 Standalone release notes for details.
Return to “Rhinoceros 3D”
